Old 01-19-2009, 09:43 PM   #1
Rokcrln
Rokcrln's Avatar
Who has 2000+ Tahoe or Burb third row seats?
I have a set of the small flip down slid out 2003 Tahoe third row seats also called suitcase seats. Does anyone have a few pics of the mounting of these? I have never seen the factory mounting before and am starting to plan out my seats in my 72 4door Tahoe so I need to figure out the mounting. I might go ahead and get the entire rear floor out of a newer Tahoe or Burb and just section that into mine since I have a bit hole left in mine since I shortened it down. I also have the second row 60/40 flip and tumble seats and full power front buckets also out of a 2000+ Tahoe that will be going in one I finish up more of the metal work.
So any info on the third row seats would be great!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 01-20-2009, 12:25 AM   #2
IAFF2407
IAFF2407's Avatar
Re: Who has 2000+ Tahoe or Burb third row seats?
go on evilbay and search "3rd row brackets" There's usually a couple of sets there. They consistantly go for $125 - $145. I'm in the market myself but I'm waiting to make down to Seattle and go to a pull apart. I'm told they are a bi#*h to take out.
since these brackets need to be recessed not flat, I'm thinking your right. it might be easier to cut out a section of the donor's floor and graft it to my Burb's floor.
anyone with experience or ideas?
Al.
1972 GMC Sierra
1972 GMC Super Custom Suburban
IAFF2407 is offline   Reply With Quote
Old 01-20-2009, 02:16 AM   #3
19723DR
19723DR's Avatar
I just purchased a 3rd row seat and I was wondering the same thing. More importantly, how do you make it work with the wood floor?
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser
71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished
93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's
98 Chevy short bed DD
97 Z71 3 Door
51 Suburban-S-10 swap
"What other hot rod can you carry 7 of your friends in"
19723DR is offline   Reply With Quote
Old 01-20-2009, 02:20 AM   #4
oldiron
Designated Grumpy Old Man
oldiron's Avatar
I know someone here has done this and they removed the floor from the donor vech. and welding the floor in their suburban. I think it was about a year ago.
OK I was wrong it was in the blazer forum. Here is a link. Same principal.
http://67-72chevytrucks.com/vboard/s...d.php?t=260518
oldiron is offline   Reply With Quote
Old 01-20-2009, 02:33 AM   #5
19723DR
19723DR's Avatar
I've seen it on a blazer, but I never seen it done to a suburban. I was thinking of welding new brackets to the seat. I'm looking for a less evasive solution. Just an idea.
97 Z71 3 Door
Old 01-20-2009, 08:04 AM   #6
Rokcrln
Rokcrln's Avatar
You know for some reason I thought the blazer guy used the third row bench. But after going back through that post I was wrong, thanks. I will start calling around for a floor section as I am in no hurry since I need to do the rear 3 link wish bone set up and step notch first anyways.
Thanks again guy's
Kevin
LFD Inc.
Old 01-23-2009, 04:11 AM   #7
kevncar
Active Member
kevncar's Avatar
Hey Kevin,
The wife's got a 01 tahoe...sounds like you're gonna find a floor to make your seats work, but if you need any pics or anything in the meantime...let me know. They're only a camera click away!
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 01-27-2009, 11:04 PM   #8
Angelo
I put some in my 72 burb. Well a body shop did the work for me they just made new brackets for it. I'l try and put some pictures later this week.
Angelo is offline   Reply With Quote
Old 01-28-2009, 12:32 AM   #9
Rokcrln
Rokcrln's Avatar
Originally Posted by kevncar View Post
Hey Kevin,
Yes I bought a floor out of a 2002 Tahoe that I should get later this week but it will sit until I get my rear suspension figured out and that means more customer work so I can afford the parts What you could get me is the dimension of the floor step that the second row is sit on from the main floor. Turns out the second row seat I have is out of a 2003 Burb and I think the Tahoe second row seat would work out better depending how tall that floor step is. If it works out right I can slid that seat back a bit more for some more leg room in the second row.
Thanks,
Kevin
LFD Inc.
