#26 |
Re: 283 or 307
Sad to say but the 283 isn't big enough for a full size pickup if you want to hot rod with it. I have one in the blue stepper. All bark and no bite. Yeah I know they can make a little Nova run but they are half the weight.
#27 |
Re: 283 or 307
If I was building a small block, I would just go with a 350, parts are cheap and plentiful.
#28 |
![]() Join Date: Jan 2007
Re: 283 or 307
67 C-30 I agree that I've some 400 blocks that were cracked or just had way to much core shift to make a good motor out of but, most of them were the early 400 blocks and mostly the 4 bolt main ones, with that said when I go to look at one its never a 4 bolt block and if it will be used for the street we just do studs on the stock 2 bolt caps if its race we do billet splayed 4 bolt caps, also I have heard about the 3.25 stroke 400 bore based motors but have never seen one heard they were very nice, but I have had my hand in a few 377" big bore motors and they love the rpm's too.
ASE MASTER TECH
#29 | |||
Re: 283 or 307
The Question:
"I guess what I want is the best of both worlds,more HP better mileage." Answer to question: Quote:
A collection of opinions on various small block configurations for various results.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-22-2009 at 09:01 AM. |
#30 |
![]() Join Date: Aug 2008
Re: 283 or 307
Talk about a can of worms here. I have run almost every SBC displacement. 267 (79 Malibu- DOG!) 283 (57 Chevy) 307(72 custom 10, 71 Nova), 327 (65 Malibu) 350 (71 El Camino, 79 Malibu (after 267), 76 C10, 82 C10, 383 (79 Malibu after 267 and 350), 400 (71 Impala I wish I had it in a little Nova or Camaro!). My Dad had a 80 GMC 1 ton with a 454, brother had a Camaro with a 454 swapped in, 76 C10 w/ a 454 (after 350), each brother had a 72 C10 with a 402. All except for the 267 and 307's had minor upgrades like cam, headers, carb, sometimes heads, nothing exotic or fancy. My point is: the 454 always had more power, but used more gas. the 283's and 327's ran good and were good in a car , or a truck when empty. IMO, a 350 is a good compromise if you do a little light towing and like to hot rod around a little. A 383 will only cost a little more to build if your core requires a new crank (don't bother with used OEM 400 cranks, there are plenty of good aftermarket cranks CHEAP). Finding a usable 400 block is more $$$ still, but they do run like a scalded dog.
#31 |
Re: 283 or 307
OK, everyone forgot to answer your question and rambled on about their favorite engine (especially me). IMO, tear down both engines and see which is in the best shape, and which would require the least amount of money. If on a budget, build the one that will cost the least at the machine shop. It will mainly come down to which engine (if any) can use he stock pistons and only require a hone job (not likely). I believe 283 and 307 cranks are the same (?) If both require an overbore, check into the cost of replacement pistons. Install a good RV type torque cam, dual plane intake, decent electronic ignition and 600 cfm 4 barrel on either engine.
#32 | |
Re: 283 or 307
#33 |
![]() Join Date: Mar 2006
Re: 283 or 307
You want horsepower and tork build a 400 but if you want good gas mileage and all around nice motor build a 327
#34 |
I have a radical idea!
Re: 283 or 307
No, a 283 has a 3.00" stroke and 3.875" bore. A 307 has the same 3.875" bore and 3.250" stroke. A 267, 305, and 350 use the 3.48" stroke.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
#35 |
Re: 283 or 307
Another note:
From what I`ve seen,307s tend to run forever.I say this from actual experiences I`ve had and what people have said.I had a timing chain jump time and the valves got bent @120,000 miles.An overhaul/rebuild was in order since I`d never do a top-end on any small block at that mileage.That block had vitually no ridge and just a hone and new rings was all it needed.The crank was pretty,too,no machining.This motoe was in a`71 K/20 with 4.57:1 gearing,not a car.
#36 | |
Re: 283 or 307
CHEVY SMALLBLOCK V-8 BORE AND STROKE 262 = 3.671" x 3.10" (Gen. I, 5.7" rod) 265 = 3.750" x 3.00" ('55-'57 Gen.I, 5.7" rod) 265 = 3.750" x 3.00" ('94-'96 Gen.II, 4.3 liter V-8 "L99", 5.94" rod) 267 = 3.500" x 3.48" (Gen.I, 5.7" rod) 283 = 3.875" x 3.00" (Gen.I, 5.7" rod) 293 = 3.779" x 3.27" ('99-later, Gen.III, "LR4" 4.8 Liter Vortec, 6.278" rod) 302 = 4.000" x 3.00" (Gen.I, 5.7" rod) 305 = 3.736" x 3.48" (Gen.I, 5.7" rod) 307 = 3.875" x 3.25" (Gen.I, 5.7" rod) 325 = 3.779" x 3.622" ('99-later, Gen.III, "LM7", "LS4 front wheel drive V-8" 5.3 Liter Vortec, 6.098" rod) 327 = 4.000" x 3.25" (Gen.I, 5.7" rod) 345 = 3.893" x 3.622" ('97-later, Gen.III, "LS1", 6.098" rod) 350 = 4.000" x 3.48" (Gen.I, 5.7" rod) 350 = 4.000" x 3.48" ('96-'01, Gen. I, Vortec, 5.7" rod) 350 = 3.900" x 3.66" ('89-'95, "LT5", in "ZR1" Corvette 32-valve DOHC, 5.74" rod) 364 = 4.000" x 3.622" ('99-later, Gen.III, "LS2", "LQ4" 6.0 Liter Vortec, 6.098" rod) 376 = 4.065" x 3.622" (2007-later, Gen. IV, "L92", Cadillac Escalade, GMC Yukon) 383 = 4.000" x 3.80" ('00, "HT 383", Gen.I truck crate motor, 5.7" rod) 400 = 4.125" x 3.75" (Gen.I, 5.565" rod) 427 = 4.125" x 4.00" (2006 Gen.IV, LS7 SBC, titanium rods) Two common, non-factory smallblock combinations: 377 = 4.155" x 3.48" (5.7" or 6.00" rod) 400 block and a 350 crank with "spacer" main bearings 383 = 4.030" x 3.75" (5.565" or 5.7" or 6.0" rod) 350 block and a 400 crank, main bearing crank journals cut to 350 size -------------------------------------------------------------------------------- CHEVY BIG BLOCK V-8 BORE AND STROKE 366T = 3.935" x 3.76" 396 = 4.096" x 3.76" 402 = 4.125" x 3.76" 427 = 4.250" x 3.76" 427T = 4.250" x 3.76" 454 = 4.250" x 4.00" 496 = 4.250" x 4.37" (2001 Vortec 8100, 8.1 liter) 502 = 4.466" x 4.00" 572T = 4.560" x 4.375" (2003 "ZZ572" crate motors) T = Tall Deck ALL production big blocks used a 6.135" length rod. -------------------------------------------------------------------------------- CHEVY 348-409 V-8 BORE AND STROKE 348 = 4.125" x 3.25" (6.125" rod) 409 = 4.312" x 3.50" (6.010" rod) 427 = 4.312" x 3.65" (6.135" rod) 1963 "Z11" SHP drag race
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 02-22-2009 at 12:48 PM. |
#37 |
Re: 283 or 307
Where are you getting your info? A 283 has a 3.48 stroke with a 3.50 bore. a 307 has 3.25 stroke and a 3.875 bore. A 265 and a 302 have 3.00 stroke, and a 307 is the only one that has a 3.875 bore.
#38 | |
Re: 283 or 307
Do that math, if you don't believe me. BORE X BORE X STROKE X .7854 X number of cylinders = Cu In. 3.500 X 3.500 X 3.48 X .7854 X 8 = 267.852 cu in. 3.875 X 3.875 X 3.00 X .7854 X 8 = 283.038 cu in.
#39 |
Re: 283 or 307
You are right, I did some more reseach and found out my book has a misprint. If you have a problem with me why don't you P.M me!!!
#40 | |
![]() Join Date: Dec 2008
Re: 283 or 307
The savings on parts will alow you to do a better, more thorough job on machine work, also will alow you to step up to Hyperutectic pistons for what cast pistons cost for the 283. Now for what he did not ask, but was answered anyway 400 blocks are siamesed bores, great for drag racing, really not the greatest for general use. Prone to overheating. The 400 VS. 383 debate boiling down to cubic inches is pretty simplistic, 17 cubic inches is not going to win a race (like anyone races 4500 LB. trucks anyway) What determines power and reliability is the ratio of stroke to bore, compression ring land (reliability issue) and most importantly the cylinder head. And if you think Cubic inches always win, My buddy has a a 3.8 litre V-6 in a tuned Grand National, ran it in the 10.5 inch radial class and made it the National Finals in Fla. about 5 years ago, he raced small blocks, and guess what, They lost on a consistant basis, it's the design, build and tune that matters, right? |
#41 | |
Re: 283 or 307
And Skirkpat...right!
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 02-22-2009 at 12:24 PM. |
#42 |
![]() Join Date: Dec 2001
Re: 283 or 307
Thanks for all the answers, very good suggestions.
Dave
68 ![]() 307 V8 Lexington,NC davideowens@lexcominc.net God Bless America |
#43 |
Re: 283 or 307
Sorry about that guys, I reckon I woke up on the wrong side of the bed. Sorry about that Cunit.
#44 |
Re: 283 or 307
Well,we know all the bores and strokes now.
#45 |
Re: 283 or 307
"USE THE 57 283 BLOCK. THE CASTINGS ARE THICKER.. i HAVE SEEL 1000 HP FROM A TURBO 57 CHEVY.GOOGLE IT. THERE IS A FULL WRITE UP ON IT. YOU CAN BORE THAT BLOCK TO 60 WITH NO WORRIES. " if i remember right,in my '57 chevy the 283 block didn't have side motor mount bosses ,it mounted by the timing cover.
70 c10 stepside ,350v8, m-20 4 speed ![]() |
#46 | |
Re: 283 or 307
BTW, everyone, his question was not " WHICH SBC IS BEST". His question was "WHICH SHOULD I BUILD, a 283 or 307"? IMO, they are pretty equal. Neither is GREAT for pulling or high horsepower/ torque in street trim. Build whichever takes the least money to get running. I had a friend of a friend who ridiculed me aboutmy 6.2 diesel being a dog. We were both on our way to the Pate swap meet in Cresson one year, both pulling loaded 16' lo boy trailer. I passed him and his hopped up 68 1/2 ton lwb 283 going up a hill. THe Banks turbo I put on later really got his goat!He hated "that damn clatter wagon". HAHA |
#47 |
Re: 283 or 307
Oh yeah...check the motor mounting on the block.I`d do the 307,if it`s good.The`57 283 would be great to have,though,if you can have it.
#48 |
![]() Join Date: Nov 2008
Re: 283 or 307
i would take a 283 over 307 any day i had a 283 bored out to 301 inone of my 57 chevy`s it had plenty of scoot just my 2 cents
bob
bondo bob ![]() ![]() ![]() ![]() ![]() ![]() http://s424.photobucket.com/albums/p...albumview=grid <<<link to my stuff and project 68 step side build |
#49 | |
Re: 283 or 307
A 307 with good heads, like a Vortec (not huge runner/flowing heads) a dual plane intake, and 600 CFM 4 BBL will flat out run the same 283, it is a great build for a daily driver that wants a truck that will keep up or beat any stockers, and still pull good gas mileage. The 307 I described snapped the frame on my Turbo Regal, One of the best engines I have built. Last edited by Skirkpat; 02-28-2009 at 12:55 PM. |
