Removing door hinges... is there a backing plate behind it?
I have the lower hinge almost off, but it feels like whatever the bolts on the cab side thread into is loose.
Is there a plate back here behind the A-pillar similar to the backer on the striker plate? If I pull these bolts loose, is that going to fall into the door and get lost? I haven't pulled the fender, I'm just using my gearwrenches to get to these bolts.
1969 C10 Stepside, 350ci, 700R4 |
Roadtrip!
![]() Join Date: Feb 2003
Re: Removing door hinges... is there a backing plate behind it?
It should be OK. It should be "caged" in there. It seems loose for adjustment purposes.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Thanks bigtime for the quick response!
Back to work... ![]()
Wow, I give up on punching the pin out of this. I'm going to buy new hinges.
