My 1979 C10 Cheyenne
Here you have some pictures from the 1979 Chevrolet C10 Cheyenne I bought one month ago. It has a standard 350ci V8.
Re: My 1979 C10 Cheyenne
Audi TT chairs
Rearwall with side pieces for speakers, covered with imitation leather Last edited by twincam1449; 03-01-2009 at 06:18 AM. |
Headliner and doorpanel also covered with imitation leather
Doorpanel trim colored black Last edited by twincam1449; 03-01-2009 at 06:23 AM. |
One problem I have: going over 30 m/h there is a 'humm' in the lower part of the car. With small vibrations.
Putting transmission into neutral still keeps the vibrations. Sometimes the humm just disappears to return a little later. Any ideas? Last edited by twincam1449; 03-01-2009 at 09:41 AM. |
the pollock
pretty pretty pretty trrruck...
seats are an interesting choice....
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
the pollock
i woudl say "tires" for your humming noise..
just my .02 cents
dang its hot
rotate tires and try again,if that doesn't move the vibration, pull the driveshaft and look at the u joints
I don't think it's the tires.
I mounted new tires and rims this saturday. The humm was even there with the old tires. Strange is that the humm is not there all the time. Even if it starts, it sometimes disappears. Grinch4om: the sound seems to come from the driverside. Last edited by twincam1449; 03-01-2009 at 09:43 AM. |
yeller
Maybe a wheel bearing. Take the truck for a drive, when you get home, see if the wheel feels warm...or warmer than the passenger side. That is often a indicator the bearing is bad.
Nice looking truck by the way.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
sweet.two tone shorty.i like it.getcha a chrome rear sport bumper when you can.i think it would really help the look.sounds like a u joint or a bearing,maybe a brake hanging.jack it up and spin it.and just feel and listen,you can learn alot.
" Never look up a dead dogs butt."
No difference in temperature after a 10 mile ride.
I'll check the U joint, but wouldn't the noise be more centered? |
Humming or harmonics at speed are usually u-joints or bent/unbalanced drivelines.
Bad wheel bearings usually translate into more of a roar/whine sound. If it's a two-piece driveline it's possible someone replaced one section at some time in the past, rendering it mismatched and out of balance.
I may be old, but I still enjoy the feeling of the earth rotating beneath my wheels... |
Could it be the pinion angle perhaps? Nice truck btw, seats look good in there.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
Sb 400 club
Nice truck you got there. As was said wheel bearing or u joints would be my first guess
1984 chevy c10, built 400sb,.(SOLD )77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
#15 |
Put the truck on heavy duty jack stands or a lift if possible. Have someone put the truck in gear and accelerate to desired speed and listen. It sounds like a driveline virbration. Driveshaft or rearend.
Jeramy '84 GMC project truck '85 Chevy 4X4 SOLD '07 Chevy Trailblazer SS 5th Annual SHPHC Car/Truck Show Pics http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT |
#16 |
This morning, driving 6-7miles to work: no humm the first 6 miles, driving 30 and 50 m/h. Then suddenly decelerating a bit on the engine and the humm started again, but only for a few seconds.
Unfortunately I won't have time to check this the first two weeks. Thanks for the replies. |
#17 |
Now that sounds more like a pinion bearing or a loose pinion nut...
#18 |
6.0 powered square
nice truck
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
| Bookmarks |
