PITbut
Re: Trans fluid cooling lines.
454 MAKES IT ROAR
That's interesting lyrikz, I have just sent my trans & converter into the shop to find out why it's dumping fluid when I park, and the guy suspects that the fluid is overheating. Now he thinks it may be the Converter slipping but what you have said has made me think on.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
#3 | |
PITbut
454 MAKES IT ROAR
The odd thing is that when I bought my Truck it came with an external cooler only,
![]() but the Rad was the wrong size for the Truck ![]() So I replaced it with this ![]() So thanks for the eye opener lyrikz...it would seem I need the added cooler.
PITbut
AHAHA.. Ya, those 4 cores are a bit spendy... thats what the PO probably did..
Old member
Here is mine. The reason I ran the cooler lines to the internal first is it doesn't cool as good as the external so I ran my lines to the bottom of Radaitor internal cooler then to the external cooler. then back to the transmission.
This should give me the coolest return tempperature. ![]() ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#7 | |
Sierra Grande Club
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
454 MAKES IT ROAR
I bought that setup from one of our vendors...Wes, at Classic Heartbeat. He put the extra bend in the line when I told him what engine and trans I was running. He may be able to give you more detail on the particular make.
Hope this helps.
My TH350 doesnt have cooler lines and my aftermarket radiator doesnt have a place for them. Should I get a trans cooler and lines for it? What kind is recommended?
