Old 03-28-2009, 11:40 PM   #1
66chevy PROSTREET
SOLD
66chevy PROSTREET's Avatar
Location: Poorest state in America(Breaux Bridge,Louisiana)
Which bags would solve this problem??
I have CPP lower arms and i THINK (99% sure)the bags are 2600's, but the O.D. of them is touching the bump stop and tubing. The bag has 2- 1" ports if that helps.
I need a bag that has a smaller I.D. that can handle a big block. A friend is using the exact set up with no rubbing?! I also tried moving the bag around with no luck.
any suggestions from experience?? my buddy VIN63 has the same setup and is using Firestone Air Spring part number 6873 - 8-inch diameter inflated (3150 lbs. @ 100 psi). Is there any others with a smaller I.D.?
1st pic is my truck-1966, 2nd pic is a 72 with same parts,
1966 CHEVY FLEETSIDE
SOLD 11-29-9
TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2
66chevy PROSTREET is offline   Reply With Quote
Old 03-29-2009, 11:52 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Which bags would solve this problem??
Looks like your bag is requiring a lot more pressure to lift.
Anyone have any input?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-29-2009, 12:52 PM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Dont know if it would work in your situation, but Slam bags dont "grow" in diameter when aired up, so that may help you get your desired O.D.
Past that, could you just cut off you bump stop mount & move it over a inch or so ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 03-29-2009, 01:03 PM   #4
66chevy PROSTREET
SOLD
i was interested in the RE-7, for the fact that they are non-ballooning, the ones i have on now are about 7". i know the stats on the RE-6 and i might have to go that route
SOLD 11-29-9
Old 03-29-2009, 03:39 PM   #5
66chevy PROSTREET
SOLD
he has stock spindals and a small block....
SOLD 11-29-9
Old 03-29-2009, 04:13 PM   #6
Inverter
Inverter's Avatar
Those are coil spring arms. Not meant for air ride w/o the (lower cups). You can make them work but will need to cut off the stop.If you plan on laying front c-member,you will need some additional trimming ,ball joint angles will be terrible.
Had same arms on my '68.
TROY
My work ~ https://www.67-72chevytrucks.com/vbo...d.php?t=799484
Inverter is offline   Reply With Quote
Old 03-29-2009, 04:15 PM   #7
66chevy PROSTREET
SOLD
Originally Posted by Inverter View Post
Those are coil spring arms. Not meant for air ride. You can make them work but will need to cut off the stop.If you plan on laying it out,you will need some additional trimming ,ball joint angles will be terrible.
no, they are bag arms, from the side they look just like the spring arms
SOLD 11-29-9
Old 03-29-2009, 04:39 PM   #8
Inverter
Inverter's Avatar
I searched their site,couldnt find any cpp air arms.
Do they look like this inside?
TROY
Old 03-29-2009, 04:44 PM   #9
66chevy PROSTREET
SOLD
Attachment 446654
nope,
you have to go down to TUBULAR CONTROL ARMS on the home page...
SOLD 11-29-9
Old 03-29-2009, 04:52 PM   #10
Inverter
Inverter's Avatar
Gotcha! Those are cool looking.Dont know about the re-7's,they are larger in diameter,when empty, than a standard convoluted.
Worse case,,,you have to cut off the stop.
TROY
Old 03-31-2009, 10:49 AM   #11
66chevy PROSTREET
SOLD
i went with the re7, hopfully that will solve the problem
SOLD 11-29-9
Old 08-18-2011, 12:55 AM   #12
gonnabg
if those bags fixed your problem id love to see some pics. i have those same arms waiting to go on my 72 and need to buy my front bags still.
gonnabg is offline   Reply With Quote
Old 08-18-2011, 08:20 AM   #13
lolife99
67-72 parts collector,…
lolife99's Avatar
Can you remove the bumpstop base?
Keith
Convert to disc brakes.
Old 08-18-2011, 10:16 AM   #14
belowme51
belowme51's Avatar
I would 1st contact CPP and see what they say, or just go with the RE7 or RE6...I had some conti bags that did the same thing on a caddy I had they just ballon too much you need something that keeps its diameter....
BUTTTT personally I would hack off the bump stop...save your $$$ for something else.
belowme51 is offline   Reply With Quote
Old 08-18-2011, 10:38 AM   #15
Tony@AirRideTech
Junior Member
you could also try moving the airspring in a little bit on top and bottom mounts to gain clearance. if thats a cheap chinese bag, I would probably look for a replacement for those anyway
Tony@AirRideTech is offline   Reply With Quote
Old 08-18-2011, 02:04 PM   #16
SCOTI
SCOTI's Avatar
I wonder what bags CPP specs for these C10 lower arms?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-18-2011, 09:46 PM   #17
tcb-1
Nothing to see here.....
tcb-1's Avatar
Slam bags did the trick for my cadillac. need something smaller that didn't "grow" like my Doms. went with the new SS line and never looked back. my next ride will have Slams on it.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
