Nothing to see here.....
![]() Join Date: Jun 2007
Original Blazer Owners: Grounding Strap Location and Number
My brother (bigdon-70blazer) and I have been trying to figure out the location and number of grounding straps for his K5 restoration. I have 3 on my 69 C-10. one on the left rear head to cab, one on the right rear head to cab, and one on the passenger inner front inner fender to the frame.
can someone check thier locations under the hood and if there are any more from the body to the frame, etc? thanks gang!
Doug ![]() ![]() The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson |
#2 | |
Re: Original Blazer Owners: Grounding Strap Location and Number
![]() Join Date: Jan 2007
I had Doug ask this question because I have 4 of these. I found the locations for 3, 2 on the firewall to the back side of the engine block (got a good pic of that) and one on the underside of the passenger side rocker box, got pic of that but did not get a pic of the last location, sometimes that happens! Please help.
#4 | |
Rods
![]() Join Date: Nov 2002
i had 2 one on the passenger side of the head on the rear to the body and one to the frame on the front of the exh manifold i think
Here are the pics of the ones I had. 1 on each side of the engine and 1 on the rocker box passenger side bottom. I can not remeber where the fourth one goes. Does it go on the radiator support somewhere? Please help and thanks!
On the 2 firewall grounds, where does the engine side bolt to? Can't make it out in the pics
ive always found them connected to the rear bottom valve cover bolts
69 chevy short wide box project 70 GMC jimmy project |
There is a hole there to the rear of the valve covers, threaded . that is where mine were.
Really... I'll have to go look, is it in the head?
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 04-12-2009 at 03:57 PM. |
Yes. Let's put it this way, thats where I think it was so that is where I put them....I had the same problem, couldn't see there because I did not take a pic. Advice...take pics of everything!
I was just down there looking, can you narrow down the search a little. Didn't see it on the head
I'm a poor spectator
If i'm not mistaken I have one (it's taken apart now) going from just above the heater box to the hood.
Nvm, it's my ford i'm thinking of...whoops.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! Last edited by Jtrux; 04-12-2009 at 09:41 PM. |
#15 | |
