Old 04-20-2009, 10:15 AM   #26
Skirkpat
Skirkpat's Avatar
Re: 1968 4 door? Is this for real
It actually looks like a Truck, Suburban, K5 Blazer. Conglomeration...LOL
How hard would it be to do this? It looks like they used the top, sides and doors of the P/u and cut the Burb behind the drivers door? That seems like alot of work, but does give you the fourth door?
Any better ides on how to approach this build from an easier angle?
Skirkpat is offline   Reply With Quote
Old 04-20-2009, 10:47 AM   #27
Hart_Rod
Hart_Rod's Avatar
Unfortunately, there's no easy way about it. Take a look at ROKCRWLN's thread called Penicillin. It will give you an idea of the work involved, especially with doing the 4th door.
R
Hart_Rod is offline   Reply With Quote
Old 04-20-2009, 12:08 PM   #28
Skirkpat
Skirkpat's Avatar
Boy, Watching Kevin's work can be almost as discouraging as it is insperational...not as easy as cutting off the back sheetmetal of a P/U and welding it on the burb is it? That was a little reality check...I gues I will stick with the 2 door ramp truck Idea for the one ton
Old 04-20-2009, 12:26 PM   #29
Hart_Rod
Hart_Rod's Avatar
Or you could just make a road trip to Idaho and get that one.......... If it were closer, it would be mine...........
Old 04-20-2009, 01:54 PM   #30
Skirkpat
Skirkpat's Avatar
That thought did cross my mind But I probaby need to finish what i have bitten off already!! Very cool project though.
Old 04-20-2009, 08:29 PM   #31
Originally Posted by factorystock View Post
Historically, GM failed to see the market earlier than they did, and farmed them out(sacrificing styling). I know Dodge, Ford and International offered cleaner factory jobs a lot earlier. This truck looks like the way the factory should have made them, they way made them in 1973 and up.
Yet GM,as well as IH,had the foresight to build the Suburban and Travelall.I think that was their crewcab.The early factory crewcabs had short beds anyway...except for IH,who ironically stopped making light trucks before the market was taken over by them.So,the first Dodge and Ford crewcabs were just for tools and small equipment that in most cases would fit in a Suburban where it was locked and dry.
