Old 03-22-2003, 12:48 AM   #1
mikep
Used to have a truck
mikep's Avatar
The old Eaton is ready to go in
Got her all cleaned up and painted. I rebuilt the carrier with new bearings as the old ones were barrel shaped. Its a 5.14 geared detroit locker unit. The date stamp on the ring gear looks to be 1958. The housing itself is 1960 vintage from a 3/4 ton fleetside which is why theres no spring pads on it. The 1960 it came from had coils too but the trailing arms were spaced about 4 inches wider than my 68's so I had to cut the pads off. I'll bolt it in place with new spring pads and weld them on the tube after I set the pinion angle and center the axle. The Locker works perfectly. I cant wait to try it. 5.14 sounds like a steep gear but it shouldnt be too much with the 32 inch tires. I'll have to try the old tape a hundred to the dash trick.
No truck :-(
mikep is offline   Reply With Quote
Old 03-22-2003, 01:12 AM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
5:14's, Wow! I guess you won't be driving to North Bend again anytime soon...
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 03-22-2003, 01:14 AM   #3
UNCLEBOB
looking good I dont think you could break one of those rearends with a sledgehammer, I tried for two years. But they weigh more than any rearend I ever had to move around. Wonder what they weigh. Track opens in a month!
68 lwb 383 solid roller,250dur, 582lift, afr 210s, 10.8 comp. edel.rpm, 750vs,1 3/4 headers turbo 400, 3500 stall,ford 9 inch 3.89 gears
UNCLEBOB is offline   Reply With Quote
Old 03-22-2003, 01:27 AM   #4
mikep
mikep's Avatar
That damned loaded carrier has got to be 180 lbs by itself. The housing doesnt seem to be any worse than a 9 inch ford and the brakes make up the rest . I'd say at least 350 total although it may be a bit more. When I bought it I know two of us lifted it in the back of my truck and that guy was a big Mofo . I had to act like one.
No truck :-(
Old 03-22-2003, 06:47 PM   #5
70c10
67-72 Addict!
70c10's Avatar
Hey Mike, Let us know how it launches!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 03-22-2003, 07:02 PM   #6
CE20934
CE20934's Avatar
Location: Help! I'm in an office park with its own network of freeways!
The center section is 140lbs. Exactly.
After it fell on my hand, I was curious. Only 10lbs lighter than my trans. Gotta love cast iron!
'67 C20--427 tall deck/SM420, 4.10 HO52 (Michigan has not been kind to the Old Man)
'95 Caprice--355 LT1/T56/3.42 8.5" 10-bolt (daily driver, almost 300k on the chassis)
'07 Outback--wife's car. 125k & counting. No head gasket or transmission issues yet. *fingers crossed*
CE20934 is offline   Reply With Quote
Old 03-22-2003, 08:19 PM   #7
mikep
mikep's Avatar
Just took it for a little trip down the road. Didnt seem all that obnoxious but I only went 40 mph. Little chirping from the tires going into a corner after a stop as you'd expect from a locker. I'll let you know more tomorrow after I hook up the rear brakes. Damned line twisted off at the hose so I have to cut the line and put a new end on it in the morning. I also have to shorten the panhard bar. The dana one was too short and the one from the '60 was a few inches too long .
No truck :-(
Old 03-22-2003, 08:27 PM   #8
casey
casey's Avatar
That sounds awesome, man you sure know your stuff
casey is offline   Reply With Quote
Old 03-22-2003, 11:33 PM   #9
GMC71k20
5.14s demand respect, you better get some smokey burnout pics on here soon
GMC71k20 is offline   Reply With Quote
Old 03-23-2003, 12:27 AM   #10
mikep
mikep's Avatar
I have every intention of doing just that!
No truck :-(
Old 03-23-2003, 01:28 AM   #11
UNCLEBOB
How long does the panhard bar need to be I have one on my corporate axle I took out, its yours if it will work.
Old 03-23-2003, 02:34 AM   #12
mikep
mikep's Avatar
Thanks UncleBob but I already got mine cut and welded up.
I must say that the dana 60 that came out of my truck was one that I have nerve seen before. Its marked 60-3E on the front and on the bottom and has the panhard bar mount cast into the housing center section....weird.
No truck :-(
Old 03-24-2003, 10:53 PM   #13
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Hey, you should show us proof of the locker!!!!!!!! Come on you know you want to.
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 03-24-2003, 11:30 PM   #14
mikep
mikep's Avatar
I'm kind of babying it until I can find a slightly longer rear driveshaft. Ive got about an inch and a half engagement on the splines at the carrier bearing which is less than I'd like. seems the eaton is a good bit shorter front to rear. the smoke show will have to wait till this weekend when I hit the boneyard for a longer shaft although I did try it out this morning at 5 AM in the work parking lot. the tires were still smoking when I parked it . looked pretty damned cool
No truck :-(
