#26 |
65 - Chevy C10
Re: Hot Rod Flat Black Paint
Thanks for the props guys! My first paint job EVER so it is what it is.
#27 |
Hey Salazar,
How much paint did you use? |
#28 |
65 - Chevy C10
I used 1 gallon. So far. I think I can use another qt though. Thats because I had to respray the cab once. I had massive striping.
#29 |
Cool, thanks for the help
#30 |
![]() Join Date: Sep 2006
Look what I ran across on e bay. And also what is pictured on the can.. http://cgi.ebay.com/ebaymotors/HOT-R...mZ220212589660 They have a website too.. www.paintforcars.com
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 Last edited by Chevy Fleetside; 08-07-2008 at 04:37 PM. |
#31 |
Wow, I wonder how long a primer like that would hold up. I love what's on the can. Lets hear some opinions on this stuff guys. Anyone ever use this?
#32 |
http://www.tcpglobal.com/kustomshop/...IT-HRF289-M-GL Here is some clear for it. If you go to the web site www.paintforcars.com you can see what others have said about the product. If you are just going to be using it for a short time then it might be ok. I have never used it.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
#33 |
cool '62 on the can!!
#34 |
65 - Chevy C10
I would say to resist the temptation on using primer alone without sealing it. Moisture will eventually penetrate it and start rusting from the underneath. All your hard work will be ruined. Just an FYI, I realize people will still do it
#35 |
As sweet as the can is, don't put that on anything you value. That primer will help it rust. There are other products that will hold up to the elements.
Chop |
#36 |
Resident Photoshop Nerd
personally, my boyfriend and I are thinking about going the vinyl wrap approach.. any thoughts to this?
.. demo shot: ![]()
PJ - 1966 C10 Panel -- Max˛ - 1964 Jeep Wagoneer Panel-delivery -- Waiting his turn Last edited by suzq044; 08-08-2008 at 08:42 PM. |
#37 |
Big Boys With Big Toys
so can you shoot hot rod flatz with a flattened clear?
#38 |
I wonder, could a person use rust oleum enamel thinned with mineral spirits in a wagner power sprayer?
#39 |
what I did when painting my frame that was sandblasted, I used duplicolor etching primer for two coats, then three of rust oleum semi gloss black.
#40 |
hot rod flatz sprays on great and uv resistant no chalk look
#41 |
sem trim black
#42 |
sem trim black
#43 |
I went with the Hot Rod Flat Black on my truck.
Turned out really well. |
#44 |
so could you?
#45 |
60-66 Nut
I'm not a professional painter, but I don't see why not if you wanted to. But I don't think you would need to since the 'Hot Rod Flatz' paint is UV resistant.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-28-2009 at 12:58 AM. |
#46 |
60-66 Nut
That looks reeeeeally sweeeet....I like it.
(dang pic wouldn't copy)
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 05-28-2009 at 01:02 AM. |
#47 |
I was shooting more for the waxing possibility and a little extra rock chip protection being as im surrounded by gravel roads
#48 |
If you want to go basecoat/clear coat then I would get a true BC/CC system, and flatten the clear. They make flattening agents for the clear coat. No reason to spray clear over the single stage HRF.
Andrew '69 C-20(292, 4-speed) Retired Daily Driver '64 C-10(250, 3-speed) Fixerupper '97 F*rd Mustang GT(4.6L, 5-speed) Daily Driver If I only wanted two pedals I'd have bought a bicycle.
![]() Last edited by MXmaniac; 05-30-2009 at 06:22 PM. |
