Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-17-2009, 10:45 AM   #11
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by RustyParts View Post
Another little neat trick with the fuel pump rod is to remove the 3/8" bolt on the front of the engine just to right of the fuel pump, you can see the rod when the bolt is removed, and install a longer bolt but just tighten it finger tight against the pump rod that will hold her for sure.
Good lookin' work trooper.
Holy crap! Voices from the past Nice idea on the bolt, didn't know that. I started to take that bolt out, but heard weird noices(crunching and crackling), so I tightened it back up. We should start a tip of the month thread
How's things with the Jimmy?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
