Amateur Rust Fighter
[ Also posted this on LS1tech but looking for opinions from any possible source. ]
Trying to piece together the fuel system for the LS1 ('99 Z28 donor) that's going into my '72 Chevy shortbed. (This is my first fuel-injected project, so please be gentle with your advice and criticism.) Here's what I have so far:
I'm planning to do braided fuel line with AN fittings all the way from the fuel rail to the tank. I already know what fittings I need for the 'Vette filter/FPR and fuel pump. I need to know the following:
Thanks in advance for the help. I have virtually no local resources and so I'm ordering everything online. Really want to make sure I get it right the first time and don't end up missing a fitting or buying stuff I don't need. Thanks again, Brent
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) |
Re: Help with fuel system design for LS1 install
Anyone have any thoughts on this? Truly don't mean to be impatient or demanding — just would like to get the parts I need ordered soon.
#3 | ||||
Next project: 1970 K10
I realize this is an older post, but it looks like you don't have an answer yet, so......
![]() Or you can use a Dorman #800121, like this (I would recommend threaded fittings however): ![]() Quote:
2] Feed line from the tank to the pump, then to the Vette filter/regulator, 3] Feed line from the Vette filter/regulator to the fuel rail. In this setup, flow from tank to engine is right to left: ![]() Quote:
http://cgi.ebay.com/ebaymotors/Gas-F...=p4506.c0.m245
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
A little late, but good info nonetheless! (Already ordered everything and most of it's here; the rest will arrive Friday.) And thanks for the link to the eBay item.
![]() My only question is whether I can use the -6 line for the return as well. The 5/16" return line connector goes to -6AN so I assume there won't be a problem. For a return line, I can't see why a bigger line would be a problem. (Too small, sure, but....) Thanks again!
Brent '72 Chevy SWB stepside - [ Build Thread ] '79 ChevMC SWB fleetside - [ Build Thread ] '64 Chevy SWB fleetside & '66 Chevy SWB stepside (waiting in the wings...) Last edited by brossow; 07-29-2009 at 02:47 PM. |
Yeah, my bad. In my application the OEM return is 5/16", so that's what rolled off my fingertips! -6 should do fine as well.
Home Built '87
Hi, just starting my fuel lines tonight...how did you connect you lines to the gas tank "spouts"?
I bought the parts from Glock's fuel system list....just wondering though how you got the line started at the fuel tank / sender? (I've never used braided lines before) So, do I: 1. cut the ends off the 3 fuel sender's tubes, 2. then put a nut on each fuel sender line, 3. then flared the fuel sender line with your 37' flaring tool, 4. then threaded your a/n end onto the nut? I am running two fuel tanks if that helps too.. Thanks!!! Thanks for your help!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
Has more rust than truck...
So your question is: How do I attach AN hose to my trucks factory pickup/sending unit?
Or am I missing something? What type of hose are you using? If you are using teflon SS hose you will not be able to clamp your hose to the sender. One option there would be to use a compression fitting to AN adapter. If you are using regular SS hose you can simply slip it on the pick up and clamp it. Hope this helps. |
TruckincrazY
I need this dumbed down as much as possible; will the dorman 800121 and 800120 work for the fuel rails in a return style system using fuel injection clamps?
My build thread - '84 2wd w/ a 6.0 swap http://67-72chevytrucks.com/vboard/s...d.php?t=433595 |
#9 | |
Home Built '87
I'm trying to find a piece-by-piece order of what to do but searching the board and even google just gives a hodge-podge of information that is only half there, if that. Any information, especially how to join the braided line to the fuel sender as shown in my pic attached would help! Thanks!!
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 Last edited by Gordonr1973; 04-30-2011 at 07:58 PM. |
#10 | |
meowMEOWmeowMEOW
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
TruckincrazY
Awesome! I will order them up. I have no intention of going down the track and really, I barely drive it. Thanks!
X2 I used a 800120 on my return line.
Ignore the rust please ![]() ![]() |
these pics need to be in the FAQ fueling section....
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
You can see and read about what I ended up doing about halfway down page 12 in my build thread, starting at post 292 (link). Here are a few pics from that thread:
#15 |
This info helped a lot. Thanks guys
#16 |
In the picture of the sending unit, what does the pipe in the middle of the sending unit do?
#17 |
Still Learning
I agree this needs to be a FAQ section. With part numbers of what everyone is using for their builds.
#18 |
meowMEOWmeowMEOW
i have all of my part numbers on the reciepts around here somewhere from my build. i can dig them up if needed.
#19 |
I'll add this thread to the LS FAQ.
#20 |
How do you connect to the regulator with hard line?
#21 |
Registered Cruiser
Possible dumb question here, but....
If there is a fuel line and return line coming from the rails to the regulator, but there is only one "input" on the regulator, then two out (one to pump and one to return in tank), where does the return line from the fuel rail go??? Does the two lines coming from the rails need to "join" before the regulator?? First LS Swap obviously... ![]()
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
#22 | |
#23 | |
Registered Cruiser
So no need for a regulator? I don't remember seeing any kind of regulator in the system?? What should the rails looks like? That would be good news, could be why I'm confused about this fuel system layout lol
#24 |
Two lines off the intake or two lines off the fuel rail? , Is the second line going to the purge solenoid by chance? Can you post a pic of what you have? Be able to give you better advice that way.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html Last edited by ls1nova71; 06-29-2012 at 02:07 PM. |
#25 |
Hey folks,
I'll jump in with a question also. I am finishing my budget for my LS1 swap and I'd like some advice. I am running an LS1 our of an 02' F body, which I believe is the "returnless" style rail. I am buying a tank with an intake Aeromotive stealth efi pump from Boyd's. My plan is to run the feed and return lines from the tank to Vette regulator, and then a single feed line to the LS1 rail. I plan on using all braided hose for simplicity of install. Approx how many feet of line did you need? I dont have the motor yet so I cant measure. Im just doing this to finalize the spreadsheet Would this kit be a good idea, along with an extra few feet (4-5?) of -4 AN line for the return + extra straight/90* fittings? I know I will need extra -6AN fittings and clamps. http://www.summitracing.com/parts/SUM-PUMPKIT1/ I've never messed with fuel plumbing other than carbed stuff. Braided line/fittings are new to me. Last edited by chevy72blu; 06-29-2012 at 02:49 PM. |
