#16 |
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
It will bolt right in. Be sure to get the u-bolt plates as the axle tube dia. is bigger. Your front driveshaft should take the same u-joint. the length should come out very close to the same. Brake hoses will be different. If you do away with those drive flanges I would be interested in them. I have a early '80s single wheel front 60 that is missing one hub/bearing assy. CAN ANYBODY FIND ME ONE PRICED REASONABLE? -Jeff
| Bookmarks |
