Old 07-22-2009, 08:33 PM   #1
8door
Not too old to learn
Smile After many years finally getting going
Here it's been 5 years of a combination of procrastination, time, working on other projects ........ya I know blah blah
Well damn it! I'm serious
Frames done .A arm bushings installed , brakes rebuilt ,power steering box in ( had old ram assist ) Painted cab .
Rebuilt t400. Installed crate 350 with stock ram horns. My plan is to make it back close to stock as possible and drive it.
Here is a few pics. Only thing that was a stumbling block is the pulleys. Read a lot about all the combinations for these engines, but I found a correct power steering pump pulley and now need to get the water pump 2 grove and crank 3 groove.
1968 C10 a way to long restoration.
8door is offline   Reply With Quote
Old 07-22-2009, 08:40 PM   #2
Boog
laying low
Boog's Avatar
Re: After many years finally getting going
You've got er going the right direction now.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-22-2009, 10:03 PM   #3
sellersrodshop
sellersrodshop's Avatar
are you running short or long water pump? i might have what you need depending on whether its short or long.
I called my stockbroker last week and asked him what I should be buying .......... he said "Canned Goods and Ammunition".
sellersrodshop is offline   Reply With Quote
Old 07-22-2009, 10:10 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice looking project, good luck with the rest of the build!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 07-22-2009, 11:25 PM   #5
8door
A short pump with power steering, so need a 3 groove crank and a 2 groove water/alt/ac
Old 07-23-2009, 03:42 AM   #6
OARNGESI
OARNGESI's Avatar
Looks good so far really like the blue
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 07-23-2009, 06:24 AM   #7
big_al_71
big_al_71's Avatar
+1 on the color!!!
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 02-09-2011, 01:23 PM   #8
8door
Got going again. Started to mock up and gets some new parts.
Went down to Classic Industries 20% off sale Saturday, picked up glass rubber, new fender emblems and a bunch of little items.
Repaired steering wheel and painted it body color.
Installed head lights with new adjusting screws and plastic nuts as well as new springs. Stripped and painted radiator mount.
Painted fan shroud,and valve covers after removing the plug wire holder built in at factory. Engine is a new 350 crate 290 hp with HEI.
Also mock up radio and old style AM/FM cassette radio.
Here is where I screwed up. Went to a lot of trouble to get some nice original Ram Horn manifolds,and had new pipes made up just to find out the crate 350 requires 2 1/2"exhaust. Found out the manifolds are 2" . Hope this won't choke engine down too much.
Old 02-09-2011, 01:28 PM   #9
8door
Here some pics.
Old 02-09-2011, 01:53 PM   #10
leddzepp
Moderator
leddzepp's Avatar
looks good neighbor! i am in riverside also.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-09-2011, 01:57 PM   #11
vectorit
What?
vectorit's Avatar
Looking good! +1 on the color as well.
Where you at in SoCal? I'm in the Temecula area.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 02-09-2011, 02:17 PM   #12
8door
Just up the road in Riverside.
Old 02-09-2011, 02:22 PM   #13
8door
This is the truck when I got it.
The second owner purchased a few years ago from original owner.
I have the original protecto plate along with an owners manual,and Cal black license plates.
Old 02-09-2011, 02:29 PM   #14
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
Very nice work. What blue is that you painted your cab? What did you paint the rams horns with?
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
Old 02-09-2011, 02:47 PM   #15
leddzepp
Moderator
leddzepp's Avatar
do you need a horn button? i noticed yours is missing
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-09-2011, 03:27 PM   #16
8door
Yep, it is sitting on top of dash you can see the edge of it just left of the wheel. I just stuck the wheel up for the picture, still have a few things to do with the power steering box before the steering is set.
Old 02-09-2011, 09:12 PM   #17
8door
Do you have an extra ? I am looking for a shift pointer?
Old 02-09-2011, 09:19 PM   #18
leddzepp
Moderator
leddzepp's Avatar
i have an extra 67/68 horn button. the only pointers i have are for tilt columns.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 02-09-2011, 09:21 PM   #19
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Cab looks GREAT!!
Ya gonna restore that dash bezel/guages too!?
John
1999 Toyota Tacoma 4x4
Old 02-10-2011, 12:19 AM   #20
8door
The paint is a special mix I had a shop mix up.... I like it
The manifolds are not painted I just bead blasted them, but will apply a coating called Calyx it is a brush on material that resists heat and will be darker color.
Old 02-10-2011, 12:23 AM   #21
8door
Originally Posted by oldblue1968chevy View Post
Cab looks GREAT!!
That is the plan after I get the engine all set to fire.
I will be searching for methods to do it, any suggestions ?
Old 02-10-2011, 12:29 AM   #22
67chevy1series
67chevy1series's Avatar
this truck looks awsome and i think i speak for all the guys when i say we need more pics!
67chevy1series is offline   Reply With Quote
Old 02-10-2011, 12:51 AM   #23
VA72C10
VA72C10
VA72C10's Avatar
It shouldn't be too bad as long as you use a muffler that's not too restrictive and keep the bends nice and smooth....
It will cut down on peak HP but won't hurt it too bad.
If you're really worried you can always sell them to someone to recoup your investment and look for some headers/other exhaust...
Old 02-10-2011, 08:37 PM   #24
8door
Thanks for the positive thought . I think what I'll do is buy a nice set of 2 1/2"
turbo mufflers, and go back a few feet on the 2' pipe already built and install a step up. Then run 2 1/2" to mufflers.
Gases expand and actually pull exhaust similar to the two stroke expansion chambers. Not knowing what the formula is,
I'll just experiment and see what happens.
Old 03-09-2011, 03:53 PM   #25
8door
Messing a little more with the 68, but stopped to build a one truck garage for it.
There are other pics of it but here is exterior.
Past few days I have been dry fitting parts in storage for so long, I forgot
how they go together
More wiring to sort and finnish engine, should be able to fire it soon.
Note to moderator: should this thread be moved to "Build section" ?
