08-11-2009, 11:12 AM | #1 |
Next project: 1970 K10
Help on ID'ing a few things on a 5.3L
Can anyone help me identify a few things on my 2006 5.3L?
#1 - Sensor on front of intake, right behind the TB: #2 - The hose that runs from the sensor in #1 runs to the back of the engine on the drivers side and was disconnected from something. What is the hose suppose to plug in to? (end of hose is #1) #3 - The vent hose on the transmission splits and runs toward the engine and ends with a check valve. the other end was loose. Any idea where that end with the "?" goes? #4 - This sensor above the starter: #5 - This module, looks as though it was on the inside of the cab: #6 - This gizmo was tied around the negative battery cable near the battery terminal end, and ran straight to the PCM: Thanks in advance for any help ID'ing this stuff!!!!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
08-11-2009, 11:37 AM | #2 | |
Just a nother gear head
Re: Help on ID'ing a few things on a 5.3L
I just had mine all apart. would have to look at the manual for exact names. Do you have a manual? if not go get one. mine was a life saver.
the hose in pic 2 conects to the port withe the 2 white dots just to the right of your hand. the sensor above the starter is the crank position sensor. Thats all i can id right now with out going out and looking at mine and fliping threw the manual. Quote:
2013 HD FLHX 2000 chevy 2500 6.0l 4x4 3dr 2000 harley fxdx 71 Jimmy 4x4- future crawler/ woods rig 71 blazer (C4 2wd conv project) http://67-72chevytrucks.com/vboard/s...d.php?t=523589 |
08-11-2009, 11:48 AM | #3 | |
No one makes a manual for a 5.3 Vortec in an 85 GMC.
08-11-2009, 11:50 AM | #4 |
I will go out and check my truck and get back to ya. just to be sure.
08-11-2009, 12:03 PM | #5 |
sorry man i was wrong. the tube is part of the evap system and connects to a metal tube that runs along with the fuel lines to the tank. so the sensor the tube goes to is some sort of vacum valve.
I took a bunch of pics with my digital during the taredown just incase i forgot where stuff went and labeled every plug i un did even tho most will only go in one place.
08-11-2009, 12:07 PM | #6 |
Cool, thanks! I'm doing away with the EVAP, so I can probably just pull the sensor out and make a dummy plug for that hole in the manifold then.
Thanks again!
08-11-2009, 12:49 PM | #7 |
On the fast track to nowhere..
1 Is the Evap system purge solenoid.
2 Is the purge hose. It goes back to the fuel system, the purge solenoid pulls fumes through it and burns them instead of venting them into the atmosphere. 3 Just hangs down, if the trans overheats and blows off fluid it will go under the truck instead of all over everything if it came out of the top vent 4 Is the crank sensor like already mentioned. 5 Is the Body control module (BCM) mostly controls interior features like door locks and such. 6 Is the Generator battery comtrol module. Basically it uses amperage draw, battery temp. etc. to regulate the battery charge voltage. If there's anything you need more info. on let me know. I have the world of GM at my fingertips... for now
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting Last edited by BACKYARD88; 08-11-2009 at 12:50 PM. |
08-11-2009, 01:00 PM | #8 |
Beauty, thanks Mike!! Is #6 necessary, or can I have to removed too? I've never seen one before. The battery on the 85 is on the passenger side, but I might move it to the drivers side to keep hooking up the 5.3 harness easier. But if I left it on the pass side I'd have to extend all the wires for the #6 thingy.
08-11-2009, 01:24 PM | #9 |
You should be able to have it removed. It defaults to 13.8v if it's unplugged or has a problem. As long as someone can program the PCM to not set the code for it all should be good.
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
08-11-2009, 02:01 PM | #10 |
Awesome, thank you for your help!!
08-11-2009, 02:16 PM | #11 |
Glad I could be of service
08-11-2009, 02:51 PM | #12 |
Well i guess you better get started then
get one for the yr of 5.3
