Old 08-17-2009, 09:28 PM   #1
dbmx66
look what came in the mail! UPDATED!!!
my kit came in the mail today, 4.5/6 mcgaughy's drop kit. 2.5 inch drop spindles, 2 inch drop coils, flip kit, c-notch. and for shocks a got 4 bell-tech nitro drop 2s.
before i start the drop , does anyone have any tips or anything that will help? thanks
dbmx66 is offline   Reply With Quote
Old 08-17-2009, 09:43 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: look what came in the mail!
Take your time, take pics,... and look at all the associated parts for defects and wear.
Nows the time to replace any bad brake or steering components.
Also use jack stand or a lift, and eye protection when cutting or grinding.
If you have any questions along the way,... don't be afraid to ask.
Welcome to the board.
Also,... what is this drop going on?
Keith
Convert to disc brakes.
Old 08-17-2009, 11:00 PM   #3
dbmx66
oh yea i know that. i've lifted and lowered trucks before. just if there were any tips on the flip kit or whatever. and yea where the truck is, is in my grandparents garage. there's every kind of mechanics/car/engine tools you can think of.
okay, i'll have to check the steering. from what i know its fine. but its doesnt hurt to check again i guess.
the drop is going on a 78 chevy c10.
thanks man!
Old 08-17-2009, 11:02 PM   #4
dbmx66
by the way, do you have any tech articles or are there any other previous threads on how other people put there kits on. just so i could check them out. thanks
Old 08-18-2009, 12:16 AM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
hears a few
http://73-87.com/7387garage/chassis_.../box_drop2.htm
http://73-87.com/7387garage/chassis_...nsion_drop.htm
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 08-18-2009, 08:09 AM   #6
dbmx66
thanks man.
Old 08-18-2009, 08:15 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Good luck with the install as I recently did a similar install on my '69. As long as you have all the pieces the install should be a breeze. Keep us posted on your progress.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 08-18-2009, 09:12 AM   #8
dbmx66
i definitely will. i'll have more pictures up as it starts coming along.
Old 08-18-2009, 09:29 AM   #9
SCOTI
SCOTI's Avatar
Start soaking the assorted threaded items now w/some penetrating oil so that when you're ready to start the parts swap, you've free'd-up any potentially stuck hardware (which is always better than fighting it for 1/2 the day).
Take pics so you can reference how things were (just in case).
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-18-2009, 09:41 AM   #10
dbmx66
good idea with the picture reference. and yea we have the bolts the need to be loosened up soaking in liquid wrench and some with 5 way penetrating lube.
thanks.
Old 08-18-2009, 09:42 AM   #11
drewfever1020
how much did it come out to?
iv been wanting to do that same drop
drewfever1020 is offline   Reply With Quote
Old 08-18-2009, 11:04 AM   #12
dbmx66
well, i bought it through stylin' trucks, there having a sale on alot of things now. i got the drop kit for $562.49 and all the shocks for around $180 everything came to around $800 with shipping included.
Old 08-18-2009, 11:46 AM   #13
lolife99
lolife99's Avatar
I'm a big "neverseize" user also. I use it on all my bolted connections.
Keith
Old 08-18-2009, 11:51 AM   #14
dbmx66
does that help loosen the bolt and nuts up? im guessing i can get that at like a lowes or a home depot.
Old 08-18-2009, 12:13 PM   #15
brn agn
brn agn's Avatar
The only advice I have is to box those parts back up and send them to me. I'll PM you my address.
Seriously, take measurements before you start. What I do is write the initial measurements from the ground to the wheel arches on a small piece of painter's tape and stick it to the fender/quarter panel above each wheel opening (less chance of losing the measurements).
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 08-18-2009, 01:26 PM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
This product is actually used when you are reassembling the pieces on your truck, and helps to ensure they "never seize" on your truck again. That way when you decide to go with bags (you know you wil... ) the pieces will come apart like that.
This is a good idea, whether you put it on tape or not. Write down your measurements for all four corners as well as the measurements for the rearend being centered. You definitely want to make sure the pieces you received provide you with the correct amount of drop, and you also want to be able to track down the road straight.
-Nate
Old 08-18-2009, 11:05 PM   #17
dbmx66
front suspension is finished, pic up soon.
Old 08-18-2009, 11:33 PM   #18
dbmx66
overall the front was pretty easy except both the blown lower ball joints which were total b*tches to get out. it took a lil under 3 hours just do do front. we will be doing the rear either thursday or friday.
took lots of pictures too
front suspension before
rear suspension before
stance before the drop
front left before new parts.
blown lower ball joint!
bad time for a blown lower ball joint.
had to take the lower control arm off to get the ball joint out.
everything almost back together.
yes i know i need new rotors!
Old 08-18-2009, 11:33 PM   #19
dbmx66
my brother putting a brake caliper back on.
need new tie-rods
front done! still on the jack stands.
after front drop, no jack stands.
same as above ^
after front drop side view
crazy rake until we finish the rear drop.
front view.
in this pic you can get an idea on how much of a rake there is.
Old 08-18-2009, 11:37 PM   #20
dbmx66
by the way, the steering column, booster brake and master cylinder are fresh too!
Old 08-19-2009, 12:03 AM   #21
westofb
I really hate wet sanding!
westofb's Avatar
you would see a lot more rake if you had the weight of the drive train and front clip on it! I did this drop on an 84 I had a few years ago...don't be suprised if you intend on using the stock ralley that they contact the control arms...you will have to do a bit of grinding on them if want to keep wheel weights on the fronts...lol. Good luck with your build!
Get several buddies around to help with the rear, getting the rear end on top of the springs is a giant pita!
westofb is offline   Reply With Quote
Old 08-19-2009, 12:06 AM   #22
dbmx66
yea it was only my bro and i so we just did front.
Old 08-19-2009, 01:55 PM   #23
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Nice work!
-Nate
Old 08-19-2009, 02:27 PM   #24
dbmx66
Nice work!
thanks man!
Old 08-20-2009, 09:57 AM   #25
drewfever1020
cool!
