Old 08-29-2009, 11:45 PM   #26
TR65
TR65's Avatar
Re: C10Slim's 66 Build Thread
Dang it Slim,
You are moving way too fast for me.
Good work!
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 08-30-2009, 12:08 AM   #27
shrunken66stroker
shrunken66stroker's Avatar
Nice truck. The spots with rust look really familiar. What size are your Cragar rims? 15?
shrunken66stroker is offline   Reply With Quote
Old 08-30-2009, 02:54 AM   #28
C10Slim
TR - Thanks, trying to strike while the iron is hot!
Shrunken - They are 16 but soon to be up for sale. I and going to replace with smoothies.
C10Slim is offline   Reply With Quote
Old 08-30-2009, 04:14 AM   #29
NF65Fleetside
NF65Fleetside's Avatar
Wow nice start, was one step from being a flintstone mobile but those patch panels clean it up nicely! run that thing til the wheels fall off!
NF65Fleetside is offline   Reply With Quote
Old 08-30-2009, 02:44 PM   #30
likaroc13
Rollin' Old Skool
looking good man...got a question for ya...is that the factory light green color on the front of your cab?
Old 08-30-2009, 10:13 PM   #31
jason65
Registerd User
jason65's Avatar
Lookin good Slim.
Last edited by jason65; 08-30-2009 at 10:14 PM. Reason: If I told ya I'd have to kill ya.
jason65 is offline   Reply With Quote
Old 08-31-2009, 09:12 AM   #32
C10Slim
Thanks. Yes it is. PO sprayed it all with satin black.
Old 08-31-2009, 09:16 AM   #33
C10Slim
Got the driver side done and most of the pass complete yesterday.
Old 09-04-2009, 12:48 PM   #34
Roadhammer
Roadhammer's Avatar
Question...Where did u order the floor/rocker panels from and which ones did u get exactly?
Roadhammer
Roadhammer is offline   Reply With Quote
Old 09-04-2009, 02:15 PM   #35
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
good looking patch work
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 09-04-2009, 05:23 PM   #36
C10Slim
Roadhammer
I ordered mine from classic parts. I have to give a plug to these guys. Oredered several parts from them in the past. They always ship the same day and show up at my door on the 3rd day. Yea Classic parts!!
They are the Triplus panels from what I have heard are the best out there.
Old 09-04-2009, 09:20 PM   #37
C10Slim
The floor and rocker project is now complete!! Just a little grinding to do on the welds but I am going to put that off for a bit. I am ready to move on to the next step. I also filled the hole for the filler neck since I am going under the bed with the tank. As you can see the big brown truck visited me today. Brought me power disc brake converstion with drop spindles and c-notch. Project for this weekend is to get the cab off the frame.
Old 09-04-2009, 10:11 PM   #38
ruffrida2005
what did you use to shave the gas filler?
Paul
Old 09-04-2009, 10:45 PM   #39
Martin64
Martin64's Avatar
He's moving the tank under the bed.
Martin Gibson
USAF Retired
1964(-ish) C10
Martin64 is offline   Reply With Quote
Old 09-05-2009, 08:49 AM   #40
C10Slim
Just took a piece of sheet metal. Held it over the hole and traced from the inside. Cut it out and welded it in.
Old 09-05-2009, 07:31 PM   #41
ruffrida2005
ok just wondering if you bought a patch for it or not. I have to do the same thing so just trying to figure the easiest way.
Paul
Old 09-05-2009, 08:14 PM   #42
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I always make a pattern like he did and cut out the metal with a pair of hand held tin snips. Hold it in place with a magnet and weld it in.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 09-05-2009, 08:34 PM   #43
ruffrida2005
thanks for the info guys
Paul
Old 09-07-2009, 03:54 PM   #44
C10Slim
Today's goal was to get the cab off the frame. Stripped the steering components and called some buddies!
Old 09-13-2009, 09:22 PM   #45
C10Slim
Pulled the motor and tranny today. Also power washed the front half of the frame so I can disassemble with out fighting 40+ years of grime.
Old 09-13-2009, 09:26 PM   #46
C10Slim
Found the answer to my question.
Old 09-14-2009, 09:40 PM   #47
C10Slim
Rear suspension removed tonight. Front will be broken down tomorrow.
Old 09-14-2009, 10:12 PM   #48
ruffrida2005
You messed up. It's always fun to play in 40+ years of grim.
Paul
Old 09-15-2009, 08:15 PM   #49
C10Slim
Today pulled all the front suspension and started poping rivets on the trans and trailing arm crossmembers. Hopefully tomorrow I can flip it and finish the bottome rivets. Then be ready to blast and paint.
Old 09-20-2009, 07:10 PM   #50
C10Slim
Today was a good day and a craptastic all at the same time. First got the c-notch in and the frame cleaned up. Painted the center link and crossmember. The while I was admiring my work I a hear a bang. I turn to look and the neighbor has just backed in to my car!!! Sucks!
