Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-08-2009, 11:56 PM   #1
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: drag radial tire pressure
I was told by the outlaw guys that if you have to run much lower that 15-17 psi you need to do some suspension tuning.
68 C-10 KID is offline   Reply With Quote
Old 09-09-2009, 09:47 AM   #2
swb85
On a budget like Fred Sanford
swb85's Avatar
At the track you want to run the pressure as high as you can while maintaining traction. Usually radials like a little bit higher pressure than bias-ply's do. I've never used hoosier DR's, but with mickey's I usually start around 22psi and start working your way down from there. Remember track prep and suspension setup are much bigger factors to traction when running radials.....they're not near as forgiving as bias-ply's.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread
'98 Camaro z28: 370ci twin turbo 370ci build
'01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD
swb85 is offline   Reply With Quote
Old 09-10-2009, 04:46 AM   #3
hotrod 80
mini truck racer
hotrod 80's Avatar
15-18 at the lowest . A little change makes a big difference . You need a good low pressure gauge and take notes on your time slips or log book to study later .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
