Old 09-12-2009, 12:24 PM   #26
Thealien
Thealien's Avatar
Re: Body bolt restoration?
Originally Posted by leddzepp View Post
Metal Ready from POR 15 works fantastic. It also leaves a zinc phosphate coating and etching that helps paint adhere and prevents further corrosion. Muriatic acid (pool acid) also works well for removing rust, just doesn't leave the coating.
This is the part I was referring to. Zinc phosphate is parkerizing (patented trade name). Sometimes when I parkerise you also get some white or streaky looking finish. It has to be rinsed and oiled or as I and may do rinsed and painted over which is a very good finish. The paint I use is molyresin which must be baked/cured for an hour at 300 degrees. Many military firearmes have just the phosphate but are well oiled over the years. I have a few and like the look.
Very resistant to corrosion but IMHO way overkill for the automotive aplication. Again just trying to add info.
Old 09-12-2009, 12:35 PM   #27
leddzepp
Moderator
leddzepp's Avatar
Yup, you have to rinse off the residue very well. Then paint and go.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 09-12-2009, 01:48 PM   #28
greasemonkey
greasemonkey's Avatar
Phosphoric acid (Ospho) works great too. My old Trooper has all metric hardware, and when I did a frame-off on it I had a hard time finding new bolts. Just submerge the rusted hardware in the acid and check it occasionally. When the rust is gone, rinse off and paint. Rustoleum Professional worked well for me, it didn't chip off even under pressure from wrenches or ratchets.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 09-12-2009, 02:14 PM   #29
Thealien
Thealien's Avatar
I think it is also called or there is a similar product called naval Jelly, basically the same I think. I have some on the shelf downstairs. I'll check next time I go.
Old 09-12-2009, 09:05 PM   #30
greasemonkey
You're right, the "active ingredient" in naval jelly is phosphoric acid. I like the liquid form better for parts I can submerge. Home Depot even carries it, people use it to etch metal and concrete.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
