09-15-2009, 10:52 PM | #26 | |
Junior Member
Re: ol Curt Suffers Setback...I think
I measured from the top and the two spots mentioned were within a half inch of each other. I measured from the spot where the door check fastens down and found there to be a 1-1/2" difference between the two sides. I definitely have to consider some more reference points before doing any work
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! |
09-16-2009, 12:03 AM | #27 |
60-66 Nut
Yes you can MIG weld stainless with mild steel wire. It doesn't produce as good a quality weld as stainless wire, but of course in this situation that isn't a big issue. It sounds to me in this case that the stainless bolt has galled in the mild steel nut. It is worth a try to weld a nut onto the remaining bolt to try and remove it though.....you never know.
09-16-2009, 06:43 AM | #28 |
1961 crewcab
09-16-2009, 09:31 AM | #29 | |
Senior Car Nut
Larry Last edited by fleetsidelarry; 09-16-2009 at 09:43 AM. |
09-16-2009, 09:35 AM | #30 | |
Junior Member
09-16-2009, 09:48 AM | #31 |
1961 crewcab
I had a hell of a time with the door bolts on my 61, a few were galled, and cross threaded from the factory I assume... they are a real fine thread, and it seemed whenever I started a bolt it would try to cross.
I ended up pulling bolts off of 2 different trucks before I found some that ran in and out real nice. I also had to grind a little of the cab away around the bolt hole to get the caged nut to adjust down far enough to get the hinge to line up. the whole process was real challenging, and I felt like giving up a # of times |
09-16-2009, 11:03 AM | #32 |
283 Drama Queen
Outstanding! That's what this site's all about!
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
09-16-2009, 01:59 PM | #33 |
Member of the longbed union.
I'm just happy I've been quoted on something. HAHA
hang in there Bob.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
09-16-2009, 02:15 PM | #34 |
Hang in there Bob! and welcome to the "Broke-a-bolt" club lol. Membership is free but careful it's like Hotel California, you can check in but you can never leave hahaha
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
09-16-2009, 08:10 PM | #35 |
Junior Member
Tried to weld a nut on...wouldn't hold. Tried to drill hole and use easy out...ended up knocking the whole plate out the back. After taking some of the rocker apart on that side was able to fish out the plate. Obviously, it must sit in some kind of tray and it was rusted.
I'm trying to decide whether to take it to a machine shop and just have them make a piece.....or sell all the parts and pieces! If I have the part made, then I have to figure how to fish it back up into place and get it to stay put....oh brother!
09-16-2009, 08:20 PM | #36 |
If you have to you can always cut the peice off the piller and weld a nut. then weld the peice back on.
09-17-2009, 07:35 AM | #37 |
Junior Member
That.....Is a DEAL! I suddenly feel a little rejuvenated. There are no bone yards around here.
I bought a big ol bottle of anti seize yesterday, and a big ol bottle of advil! I am not sure t wasn't just a bit cross threaded. All five other bolts turned like they were in butter.It had only been in ther efor a day.Either way, I don't thinkI will be using them for the fine thread parts.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 09-17-2009 at 07:35 AM. |
09-17-2009, 08:16 AM | #38 |
Registerd User
Nice hook up.
09-17-2009, 10:30 AM | #39 |
283 Drama Queen
It doesn't get any better than that!
09-17-2009, 10:49 AM | #40 |
Junior Member
You got that right...especially after I snapped an easy out off in the bolt this morning!
09-17-2009, 04:29 PM | #41 |
yeah that probably isn't that good Bob.
09-21-2009, 08:40 PM | #42 | |
Junior Member
I want to make sure I have this absolutely right. From the BOTTOM edge of the drip rail to the edge of the rocker where the door meets it is 51" front and back. Correct? It appears I am at 50-5/8" on the back and 51-1/2" on the front. Roughly a 1/2" shift front and back. That would seem to make a big difference.
09-21-2009, 09:48 PM | #43 |
Measure a million times, Weld once. haha Hang in there. Atleast you get to work on your truck. Mines 4 hours away.
09-22-2009, 06:47 AM | #44 |
Junior Member
Yeah, I just want to double check the height before I start the grinding and begin resetting.
09-24-2009, 01:42 PM | #45 |
I like a week away from starting on my "repop" rocker installs from LMC and im scared to death by this thread..I think ill go out and buy a sixpack of measuring tapes that might make me feel bteer. LOL
Jory |
09-24-2009, 03:18 PM | #46 |
Junior Member
Mine are good to go now...at least i think. Will be putting door on this week. One of the things I didn't do, because I thought it would limit my working room is to brace the cab first. I also rented a video set and that guy didn't brace. Alan has some good info in his threads for this work(he definitely braced). I don't know if I have ever seen anybody as good as him on body work. I would follow everything he did!
09-24-2009, 08:58 PM | #47 |
Junior Member
Hey,
Wanted to let everyone know Mailman hooked me up with part of a pillar so I can fix my drivers door hinge pillar. Not only did he cut it out and send it, he blasted it....heck, ol curt kinda shivered when I was holding a blasted piece up to him. He hadn't ever seen one of those before!! I was busy working on getting it all lined up before cutting it out tonight and didn't take any pics, but will tomorrow. Thanks again Ken!!
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! Last edited by ol Curt; 09-24-2009 at 09:00 PM. |
