Old 09-26-2009, 01:58 PM   #1
Chlsnk
Chlsnk's Avatar
Is this what I need?
After alot of reading I have decided it is a better option to bag the front suspension of my truck to lower instead of using drop springs.
I have come into contact with a local guy who has
2 chassis tech 2600 bags dual port 1/2 in 4- 350psi 1/2 in valves two plates
and a 5 Gallon tank I can pick it up pretty reasonabley.
The truck Im looking to bag is a 84 C-10 I am wanting to keep the stock A arms until I have more money to invest in tubular.
I am wanting to know is the chassis tech 2600 bags the correct type of air bag I will be able to use on my front suspension?
****Question 2***
To use the stock A arms Im going to have to use cups for the bags to sit in correct?
Is a 5 gallon tank enough volume to use for a front suspension bags or will i need something bigger?
***My 84 short bed build up*****
http://67-72chevytrucks.com/vboard/s...68#post3481968
Chlsnk is offline   Reply With Quote
Old 09-26-2009, 03:58 PM   #2
mycool72
mycool72's Avatar
Re: Is this what I need?
5 gallons is enough yes, however I wouldn't use chassis tech products to bag my matchbox car. Plates go on the tops of the bags but cups for the bottom.
mycool72 is offline   Reply With Quote
Old 09-26-2009, 06:24 PM   #3
ndametz32
Fire Truck
ndametz32's Avatar
chassis tech is crap from what i hear.
-Nick
'83 Chevrolet Silverado Stepside
http://67-72chevytrucks.com/vboard/s...d.php?t=349394
ndametz32 is offline   Reply With Quote
Old 09-26-2009, 07:33 PM   #4
p8ntballer1911
Bodydropped71
p8ntballer1911's Avatar
Chassis tech is crap... I would go with some slams or dominator bags.
p8ntballer1911 is offline   Reply With Quote
Old 09-26-2009, 08:27 PM   #5
jjjmm56
jjjmm56's Avatar
I have 2 chassie tech add 2 air lift dom 2600 bags. The air lift are a much better grade rubber. The price is a little more but if it saves you a tow home. The only reason I got the C/T bags is a buddy lost his job and needed cash,so I"ll take the chance there brand new and I have other spares just in case.
jjjmm56 is offline   Reply With Quote
Old 09-27-2009, 01:13 AM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Chlsnk you are on the right track, but I would be reluctant to run used bags especially if they are AIM/Chassis Tech. If the valves are AIM/Chassis Tech I would pass on them too.
The plates should be fine, and one 5 gallon tank is enough for front and rear.
Yes, you will need cups with the stock arms.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 09-27-2009, 02:10 PM   #7
Chlsnk
Chlsnk's Avatar
Im still alittle unsure on putting it together and how it should properly be done. Is there any good write ups you would recomend me to read? N2Trux I read your write up you have linked in your sig and what you had on your truck before with the new stuff was exactly what I wanna do!
