Old 09-27-2009, 10:59 PM   #1
Pont406
'72 brake hoses help
I am installing a 72 c-10 disc brakes on a 69 truck. I bought front brake hoses and stainless inline tube lines a while ago. Right side brake hose has a bigger fitting where it connects to a hard line. I tryed autozone to see if they have hoses to compare but they don't. Did I get a wrong hoses or do I just need an adaptor? Inline tube kit dosn't have any adapters. Thanks
Pont406 is offline   Reply With Quote
Old 09-28-2009, 01:09 AM   #2
JJanzen
JJanzen's Avatar
Re: '72 brake hoses help
With the correct 72 hardlines, the two fronts are different sizes thus the reason the two brake lines are different. Did you check your hard lines and are they the same?
Blue72
Red72
JJanzen is offline   Reply With Quote
Old 09-28-2009, 07:30 AM   #3
69ShortStep
69ShortStep's Avatar
Went through this a few years ago when i converted my 69 with parts from a 72. Do not remember one side's fitting being bigger than the other. Maybe I got lucky and installed them on the correct side on the first try.
Autozone and Advance did not carry 72 c-10 hoses at the time.
Advance suggested using hoses from a Impala/Caprice.
Ended up ordering 72 c-10 brake hoses from Napa and had to wait a couple days for them to arrive.
69ShortStep is offline   Reply With Quote
Old 09-28-2009, 06:49 PM   #4
project7206082
im having the same problem on my 72 I bought braided hoses from cpp and stainless lines from inline tube and the passinger side is a different size than the line. cant find any sort of adapter
project7206082 is offline   Reply With Quote
Old 09-28-2009, 07:25 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
JJanzen is correct.
Keith
Convert to disc brakes.
Old 09-28-2009, 07:56 PM   #6
Pont406
Hardlines are the same. I'll try to find the adaptor. If not then I'll buy another hose for the left side.
Old 09-30-2009, 01:55 PM   #7
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
I ran into this years ago...The OEM hoses are different sizes (?) and the after market lines are the same size. CPP has adaptors for this.
I didn't like adaptors, so I now have my own lines made up from patterns & specs I provided.
PICKMUP is offline   Reply With Quote
