Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Electrical > Truck Audio
Old 09-28-2009, 04:46 PM   #1
tphsmith
still buypickupparts
tphsmith's Avatar
key on run and
key on acc. is there a wire under the dash that works in both positions so I can hook up a radio?
Its Gonna be a Great Day, I woke up this Morning.
72 SWB Fleetside freshly painted. putting a 94 LT1 with
700R4 tranny lowered 4 in the front 6 in the back
81 chevy half ton 350
89 Silverado 4x4 going ta church truck
tphsmith is offline   Reply With Quote
Old 09-28-2009, 05:14 PM   #2
texanidiot25
Eat My Rust
texanidiot25's Avatar
Re: key on run and
In the fuse block there is a tab that you can tap into that's labeled radio. It's on with the key and acc.
texanidiot25 is offline   Reply With Quote
Old 09-28-2009, 06:14 PM   #3
tphsmith
tphsmith's Avatar
Re: key on run and
well I hooked the radio memory, (aftermarket radio ) into the fuse block as suggested with a jumper and it does work with key on and acc. but I also checked to see with a test light for battery drain and, with the jumper in the radio fuse block point, it has battery drain. what I'm really seeking is a heavy gauge wire to tap into and add additional features to this wire threw a fuse block connected to a point where the wire has power with acc. and key in run position, with no battery drain, PLEASE HELP
Old 09-28-2009, 06:24 PM   #4
Boog
laying low
Boog's Avatar
Re: key on run and
I'm probably missing something here but if you plug a test lamp into a powered terminal and ground the other end the lamp will light up and there will be battery drain. If the bulb's lit it's a drain on the battery. Turn the key off and the drain should stop.
Boog
Old 09-28-2009, 07:02 PM   #5
texanidiot25
Eat My Rust
Re: key on run and
Radio should be dead when the key is off. Memory should goto an "always on" source.
The only other thing ran on the ACC power is the AC blower I think (My AC is half gone so I don't mess with it), and it does have some heavy gauge power to it.
The FAQ here has a few detailed wiring schematics of the truck if you need them
