67-72 Addicted
Removing Dana Pitman arm
what is the proper way to remove the pitman arm? Ive got 2 D44 and i cant get them off! I removed the nuts... and got 2 of the tapperd things out. Ive tried penatrating oil and heat, hammer and air chissel.w
'72 K20 |
#2 | |
Re: Removing Dana Pitman arm
Hammering is really the only way. Usually by the time you have 2 of them out, it gets easier....
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
You are referring to the steering arm. The pitman arm attaches to the steering box. To get the steering arm off, hit it hard, from the side, with a big hammer. What you want to do is to momentarily deform the bolt holes so that the tapered inserts will pop out. Then the steering arm will fall right off.
Tim |
Big hammer!!
Hit it down, out on the drag link end. Then hit it up. Then hit it sideways. Cuss. Soak with penetrant of your choice. Repeat.
72 k/10 short wideside 72 k/5 Blazer 72 K/5 Blazer - obstacle course racer 72 custom/10 8' bed 70 K/5 Blazer 67 C-30 GMC Flat bed 86 GMC K2500 Plow Truck 85 GMC K3500 84 M1008 85 M1008 77 G30 Motor Home 72 Sears 12hp Tractor Glenmoore, Pennsylvania |
For scheduling purposes you can figure it`ll take ya about 3 beers.(or beverage of choice).
67-72 Addicted
Thanks guys, i figured it would be kinda simple. I moved up to a much bigger hammer and eventualy a wedged punch. Took a little longer than I thought, probably a six pack if i had one lol. The next one I need to remove is on a knuckle that is not attatched to the D44 anymore...
'72 K20 |
#7 | |
I'm sorry....
hit it from all angles like described above and another trick ive figured out is taking a chisel or a punch and hitting the cone washer where it is split so it turns in the hole in the arm. From what ive seen its always the cones that it is stuck on.
1972 C10 cheyenne super -350/th350 Wifes truck 1971 Nova- 6.0l with some goodies and a t56, 98-02 camaro brakes all around, tubular control arms, etc 2000 zr2 blazer- rock crawler offroad toy, one ton axles and lockers front and rear. 2006 2500hd- 500hp duramax/built allison trans,traction bars, and some other goodies. |
you can try to get something to wedge the cone waser apart
