Old 11-04-2009, 09:25 AM   #26
70 Suburban
Rods
Re: Disc swap track width questions
ill get the pics to you tomarrow,I have then in a file.
i WISH YOU HAD THE PICS. ITS JUST NOT THE SAME WITHOUT THEM
Just keepin it simple.
1965 C-10 Ext cab build. 350??(Does it count at 2 truck if I had to cut one up?)
1966 C-10 lwb 283 auto
1970 Suburban in pieces
1971 Blazer 4wd....restore someday. all factory CST
1972 Blazer 4wd parts truck still a roller
1972 GMC Sierra Grandee
1998 Chevy ext driver.
2005 F**D the wife drive...(cant fix women)
70 Suburban is offline   Reply With Quote
Old 11-04-2009, 06:50 PM   #27
777ralph
I know that the correct upper ball joints will press into the 63-66 upper arms. Will the whole 73-87 3/4 ton upper arm bolt up? The idea being that you could have newer style rubber bushings on upper and lower A arms, and the 2000 spindle and brakes bolt in, for a 6 bolt conversion, using a 3/4 ton donor.
Ralph
777ralph is offline   Reply With Quote
Old 11-04-2009, 06:55 PM   #28
70 Suburban
Rods
They dont press into the upper they bolt in.. You can use the upper arms from the 1/2 ton and 3/4 ton also
Old 11-05-2009, 12:10 AM   #29
777ralph
"They dont press into the upper they bolt in.. " Yeah, i goofed. Guess I had the lowers on my mind. So the upper A arms can be used too! Thanks!
Ralph
Old 11-05-2009, 01:56 AM   #30
Captainfab
60-66 Nut
The 3/4 ton LCA's that I've seen used the steel bushings on the shafts like the '63-'72 1/2 ton LCA's That's not to say that somewhere in the mid to late 80's they don't have the rubber bushings, I just don't recall seeing ones in those years.
Ralph
Old 11-05-2009, 09:04 AM   #31
70 Suburban
Rods
Mine are from 87 3/4
Old 11-06-2009, 01:01 AM   #32
Captainfab
60-66 Nut
I just re-read your install instructions, So apparently they have the rubber bushings. I wonder when GM made the change?
Learned something new today
Old 11-06-2009, 09:12 AM   #33
70 Suburban
Rods
They went in like a charm.and it took the sqeak out of the front.
Old 11-07-2009, 01:50 AM   #34
Captainfab
60-66 Nut
Yeah I hate listening to that squeeking while driving slow.
