#26 |
Re: Can you find the vibration???
Your speedo cable is enetering in the same position as mine on the drivers side
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 11-10-2009 at 06:51 PM. |
#27 |
In late but is that cross member really only held in with one bolt in the photo at post 6? Don't know if that would cause your problem (maybe the cluck) but definatley not good. Factory came with 4 bolts per side, two each on the top and bottom rails. There is a lot of weight on that single 3/8" bolt.
#28 |
Kid's Mechanic
Is there a chance that the front driveline is engaged with the hubs turned to unlock? that will make it vibrate.Ummm don't ask how I know that.
#29 | |
son, i have a manual 465, with a 203 and 205 doubler runing down to a 14bff with a detroit. when i accelerate all you hear is screaming bbc power, when i am up to speed all you hear is bogger whine, when i am slowing down all you hear is bearing and gear clash. |
#30 |
#31 | |
#32 | |
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
#33 |
No, two per side should work, I was thinking if there was only one the support might be rocking.
#34 |
So, I found out that the cab of my truck is a 2wd cab, the 2wd hump was cut out and retro fitted with a 4wd hump. Although this modification was done the transfer case was hitting the underside on the bed which led me to question the crossmember. After measuring the crossmember on my truck against a stock 4wd crossmember I found mine was an inch and a quarter short. I fabricated a spacer and fitted to the truck today, the vibration is significantly less noticeable. Almost not at all! I would say problem solved. There was also a broken motor motor mount, which was replaced today also.
Question though.... where can I find a 4x4 crossmember??? And thank you everyone for sharing your knowledge. |
#35 |
what do you need one for, you fixed it.
#36 | |
Everything is work in progress
![]() Join Date: Apr 2006
They make at least two different tail outputs that have the speedo in different positions. The one picured is about 9 o'clock (low) and the other one is about 2 o'clock (and high). And no you can't rotate them.
Good luck with your truck! How much?! It's just an old truck part!! 49 International on a 80 GMC 3/4ton 4x4 chassis 48 International KB-5 2 ton dump bed 04 Honda CRF "500" 09 Honda CRF450 fuel injected rocket 03 Suzuki hayabusa carbonfiber wheeled monster. 02 Ford diesel stretch van (toy hauler) 01 38' Monaco diesel pusher motorhome Last edited by cobinder; 12-26-2009 at 03:15 PM. |
