Old 11-16-2009, 09:37 AM   #1
andrewmp6
Another big brake company
I found this on abs power brakes site http://www.abspowerbrake.com/bigbrake.html
Old 11-16-2009, 01:02 PM   #2
DjS71
Re: Another big brake company
Wonder if the use different calipers in the front than the ones pictured. Looks as though they're wasting that extra inch of rotor.
1971 C10 Short/Fleet 307-2BBL/3OTT
1999 Silverado 2500 ECSB 6.0/4L80
DjS71 is offline   Reply With Quote
Old 11-16-2009, 01:44 PM   #3
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
I'm really liking those 14.5's but I'm also curious about the fit with the rotors?
Anyone have prices?
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 11-16-2009, 07:54 PM   #4
68 short step
i ordered a set, and will let ya know bout the fit soon
68 short step is offline   Reply With Quote
Old 11-16-2009, 08:17 PM   #5
mrenj23
mrenj23's Avatar
2nd prices??
mrenj23 is offline   Reply With Quote
Old 11-16-2009, 09:42 PM   #6
Hart_Rod
Hart_Rod's Avatar
Originally Posted by mrenj23 View Post
2nd prices??
x 3
Hart_Rod is offline   Reply With Quote
Old 11-16-2009, 09:47 PM   #7
68 short step
you'll have to contact them, but doug there, said its 3600$... that includes everything
drop spindles, drilled slotted rotors, brake lines, electric master cyl., everything neccessery to install.... so we'll see how well the kit goes together....
Old 11-16-2009, 09:48 PM   #8
Hart_Rod
Hart_Rod's Avatar
Originally Posted by 68 short step View Post
you'll have to contact them, but doug there said its 3600$... that includes everything
Front and rear?
Old 11-16-2009, 10:00 PM   #9
68 short step
Originally Posted by Hart_Rod View Post
Front and rear?
yes front and rear. 14.5" rotors and 13" rear...
Old 11-16-2009, 10:24 PM   #10
stunna
Dam!! thats high! I like big brake kits and all but do you really need 14.5 inch rotors? Not to hate on the guys who can afford it and want it, all I'm saying is do u really need this for daily drivers, show vehicles? Sounds like you would need for a track truck.
stunna is offline   Reply With Quote
Old 11-16-2009, 10:27 PM   #11
scotts62
One day...
scotts62's Avatar
na im good ill stick with my 9inch with and stock 74 front crossmember with disc all 4 corners
Originally Posted by stunna View Post
Damn!! thats high! I like big brake kits and all but do you really need 14.5 inch rotors? Not to hate on the guys who can afford it and want it, all I'm saying is do u really need this for daily drivers, show vehicles? Sounds like you would need for a track truck.
Yeah im with you there...
I can do a whole lot to my truck for $3600
Scott
93 crew cab build
Project 62
Old 11-16-2009, 11:35 PM   #12
68 short step
if you price simular kits from bear, wilwood, ssbc you'll find that this kit is priced about par with the other manufactures.... but what this kit has to offer the others dont, is their all electric powerbooster/master cyl. setup (which is 1G by itself)...
Old 11-17-2009, 09:03 AM   #13
andrewmp6
I know the calipers are copies of the mustang Kelsey - Hayes 4 piston used 64-69.But the pistons are a lot bigger tho.Yeah there priced about the same as a big disc kit from anywhere else but the one piece rotor would be nicer then the 2 piece most others use.
Old 11-17-2009, 01:24 PM   #14
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Sure hope you have much better luck with the electric boster setup then my buddy did. After a number of attempts to get it (and the whole brake system) to work correctly, we pulled everything and went with a Baer setup and a Hydraboast. Works awesome now!
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-18-2009, 07:01 AM   #15
andrewmp6
They have a Hydraboast and normal brake booster if you want to use those im sure you can.
Old 11-18-2009, 12:49 PM   #16
chevy_mike
chevy_mike's Avatar
Yeah but by the point he decided to swap everything, he had already had them replace the electric booster once and the rear brake kit (not the big brake kit you show) was based off the Cadilac calipers, which is a craptasic system and never got to work correctly. He had a ton of money into the car and just went with a known good system.
Old 11-18-2009, 08:02 PM   #17
68 short step
id be instrested to know what the prob. was... the electric portion of the master cyl. is a seperate piece, and if it wasnt working then the master would function as a normal (non powered) master...also i know these calipers are based off brembo, so thats good..
Old 11-19-2009, 12:51 PM   #18
chevy_mike
chevy_mike's Avatar
First, it never really gave much of a boost and was really loud. The second one wasn't much better. Yes the brakes worked but it was more like manual than any assist. If he wanted manual brakes, he could have saved a bunch of money.
His Hyrdatech hydroboost has been working great once it was bleed fully. You have to blead the booster (unrelated to the brake fluid) system with the power steering system to get it working correctly.
Old 11-22-2009, 10:02 PM   #19
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Sweet, Ya I didn't see a price either. All I need is the rotors and calipers. I'm curious how much for just that.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 11-24-2009, 07:30 PM   #20
r1lorenzini
13 inch full kit with booster is 2k just called
r1lorenzini is offline   Reply With Quote
Old 11-26-2009, 01:42 AM   #21
68 short step
they are massive, 14.5" rotors all round, 4 piston polished alumnium brembo style calipers, and braided brake lines....also got another electric style master cyliner/power booster....
the calipers are 12" long and nearly 7" wide, and they look BIG, as well as the ROTORS themselves....everything installed with no problems, except the rears....the rear caliper mounting bracket mounting holes were off by
.25"..keep in mind tho, im running a ford 9"..im gonna call the company (abspowerbrake.com) and let them know, so they'll send me the correct brackets...but here is how big they are, and them mounted on the truck with 22s and 20s
Old 11-26-2009, 01:42 AM   #22
68 short step
Old 11-26-2009, 04:35 AM   #23
andrewmp6
Looks good let them know which 9 inch you have there is 3 different ones.I bet it will stop like a sports car when you get it done.
Old 11-26-2009, 11:03 AM   #24
68 short step
i did let them know, i also faxed them their measurement sheet they had me fill out...so i dont know what happened..
Old 11-26-2009, 02:42 PM   #25
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Looks awesome. Can you give us the weight of what each caliper weighs? And also the weight of each rotor. I am curious, and maybe some others are too. I seen these in the Super Chevy magazine. Thanks!!
