Old 11-24-2009, 09:35 PM   #1
blown luv
2wd to 4wd
I have an 86 crew cab 3/4 ton 2wd.I have a chance to buy an 82 3/4 ton 4x4 suburban. Will all the brackets and crossmembers fit my frame?
blown luv is offline   Reply With Quote
Old 11-25-2009, 04:35 PM   #2
blown luv
Re: 2wd to 4wd
WOW!!! I must be doing something no one else has ever done!!! It's so amazing everyone is speechless!!!!
Old 11-25-2009, 04:45 PM   #3
vern350
like a rock
vern350's Avatar
Re: 2wd to 4wd
This sway its not the most common thing to do and a few people have done it, just gotta search around. Anyways, I did this swap and found some differences. I was trying to swap 4x4 3/4 suburban brackets/crossmembers/etc to a 3/4 ton 2wd drive frame. The height between the frame rails was different and the rear hangers off a suburban will be different. You'll need them off a pickup, 3/4 ton or 1/2 ton will work. Its still work in progess, but heres the tread. I suggest measuring before you purchase, but the rear brackets will be different.
http://67-72chevytrucks.com/vboard/s...d.php?t=222438
vern350 is offline   Reply With Quote
Old 11-25-2009, 05:49 PM   #4
blown luv
Re: 2wd to 4wd
Thanks for the heads up.. I can use the hangers thats already on the p/u. Thanks again.
Old 11-26-2009, 07:17 AM   #5
vern350
like a rock
vern350's Avatar
Re: 2wd to 4wd
4x4 and 2wd pickup rear hangers are different.
Old 11-26-2009, 08:44 AM   #6
b454rat
Re: 2wd to 4wd
You can use the stock hangers on the rear of the truck now, but will have to lift it 3-4 more inches to sit level.
I did a 4wd swap to my 89 crew. Used 1/2 hangers for the rear, and B52 kit up front. Front has 4" springs and 6-7" long shackles, rear has stock 1 ton springs, small lift build into the spring perch, and about a 2-3" lift from a shackle flip.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
