Old 12-01-2009, 08:14 PM   #26
kyull67
kyull67's Avatar
Re: 67 cst
Looks like a great start!
kyull67 is offline   Reply With Quote
Old 12-01-2009, 08:14 PM   #27
kyull67
kyull67's Avatar
Re: 67 cst
what's up with that wire through the jamb?
Old 12-01-2009, 08:35 PM   #28
vegaschevy
Re: 67 cst
you are off to one hell of a great start!!!!
You are doing what I would love to do to mine!
vegaschevy is offline   Reply With Quote
Old 12-01-2009, 08:36 PM   #29
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Re: 67 cst
An awesome truck to start with! I will definetly like watching this one come together!!
ChuckDriver is offline   Reply With Quote
Old 12-01-2009, 09:57 PM   #30
GASWAGON
AMERICAN IRON ADDICT
Re: 67 cst
Originally Posted by Hottrucks View Post
2500 miles and you took it apart..lmao!!! this is going to be a killer truck in NE....do me a favor and be gentle on my truck carpet....Did you pick up any goodies at Summit?
How long was your trip??
and how are you planning your drop..I noticed no pics of LCA
where in mass are you?? we don't have any good powder coaters up here that can take a part that big..and I'm sure your not that far from me and It might be an option for my next build
Thanks for the compliments! The trip was just over 2500 miles and took me 3 days. I drove some long days! It was a blast! Your welcome to the carpet if you need it! I live in the Worcester area.The powder coater I used was in Quincy Ma. He was the only one that could take the long bed frame. He has a 40 ft. oven! For the smaller parts I have another guy who does nice work reasonably. For the drop I am going 4.5 front with 2" springs and 2.5 spindles from Cpp and the factory LCA. The rear is 5" with springs and the Cpp trailing arms and crossmember, shocks etc. I also will be upgrading to disk front brakes and a quick ratio steering box.
GASWAGON is offline   Reply With Quote
Old 12-01-2009, 10:02 PM   #31
GASWAGON
Re: 67 cst
Thanks! The wire is for the speakers in the doors. It was done prior to my ownership, but was done very nicely so I decided to keep them.
Old 12-01-2009, 10:05 PM   #32
GASWAGON
Re: 67 cst
Thanks I appreciate it. You can do it! Just takes time.
Old 12-01-2009, 10:06 PM   #33
GASWAGON
Re: 67 cst
Thanks!
Old 12-01-2009, 10:28 PM   #34
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
Re: 67 cst
I noticed you have a pretty engine in your avatar........Hmmmmmm
Hottrucks is offline   Reply With Quote
Old 12-01-2009, 10:42 PM   #35
GASWAGON
Re: 67 cst
That's the picture of the engine I built for my first 67. I pulled it and the tranny and sold the other truck. 355 roller motor, forged crank rods, pistons etc. GM alumn. heads, 10.5-1 comp. rpm air gap, Quick fuel 750 dp, etc.
Tremec TKO 600 trans. Thats now the drivetrain for this truck.
Old 12-01-2009, 10:53 PM   #36
Hottrucks
Hottrucks's Avatar
Re: 67 cst
KOOL but you better find some shorter headers
Old 12-02-2009, 09:09 PM   #37
GASWAGON
Re: 67 cst
Those were for the truck I sold which wasn't lowered. They fit poorly so I sent them back and bought a set of Dougs.
Old 12-02-2009, 09:22 PM   #38
Hottrucks
Hottrucks's Avatar
Re: 67 cst
hey you goingto the big E in january
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Old 12-05-2009, 09:25 PM   #39
GASWAGON
Re: 67 cst
Whats the dates for the show?
Old 12-05-2009, 09:47 PM   #40
SCOTTMO
powdercoater
Re: 67 cst
Going to be a clean ride,keep up the good work.
SCOTT
SCOTTMO is offline   Reply With Quote
Old 12-05-2009, 10:13 PM   #41
GASWAGON
Re: 67 cst
Thanks!
Old 12-06-2009, 09:04 AM   #42
Hottrucks
Hottrucks's Avatar
Re: 67 cst
the 16th and 17th
Old 12-06-2009, 10:03 AM   #43
chevy88
chevy88's Avatar
Re: 67 cst
Now that's just are sharp looking motor.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 12-06-2009, 08:51 PM   #44
GASWAGON
Re: 67 cst
the 16th and 17th
I think I can go. Are you planning on going?
Old 12-06-2009, 08:52 PM   #45
GASWAGON
Re: 67 cst
Thanks, I try
Old 12-06-2009, 08:59 PM   #46
GASWAGON
Re: 67 cst
Thank You!
Old 12-06-2009, 09:06 PM   #47
GASWAGON
Re: 67 cst
Made some progress in the last couple of days. stripped the seam sealer off all the joints on the cab. A real pain in the a@#, but well worth it to keep the truck nice for years to come.
Old 12-06-2009, 09:12 PM   #48
GASWAGON
Re: 67 cst
I also used a da to prep the bare metal and interior for primer. I cut out the trans tunnel and drilled the holes to install the high hump needed for the tremec 5spd.
Old 12-06-2009, 09:25 PM   #49
PHAT TONY
PHAT TONY's Avatar
Re: 67 cst
Post #35; nobody has mentioned the vintage cross-ram intake pictured!!! You using this!?!?
1972 factory 2 Wheel Drive Blazer-Sold
1972 K10 4X4-Sold
1971 Chevrolet Cheyenne/10-Sold
1970 Chevrolet C/10-Sold
1968 GMC 4X4-Project
1968 Chevrolet C/10 Pro Street
1970 GMC 3/4 Ton-Parts
1997 2WD 2DR Yukon-Sweet
http://67-72chevytrucks.com/vboard/s...d.php?t=335664
PHAT TONY is offline   Reply With Quote
Old 12-06-2009, 09:28 PM   #50
GASWAGON
Re: 67 cst
Friday we moved the cab into the booth and seam sealed the floors and rockers with metal 2 metal seam sealer/ panel adhesive. Much stronger than seam sealer and it's sandable. They use this stuff bond quarters on alot of the new cars etc. without welding. Today he sprayed the floors and firewall with dp-90 epoxy primer. After a quick bake he layed down some color base coat and then clear. Tomorrow we will tape the floors and fire wall and then prime the rest of the cab and start on the body work. Hopefully it won't take too long! I have to give thanks to my great friend Wayne for his help, time, killer body work skills and use of his shop to complete this part of the project. If any of you are in the area and want nothing but the best, PM me and I will put you in contact with him. I will update when I have some more to share.
