Old 12-01-2009, 01:41 AM   #1
Musclerodz
Great Pumpkin 95% done. 68 K20 nut and bolt rebuild
Since the 4wd project section is not viewed alot, I thought I would post up pics here of this 23 month project I am glad is almost over. Basically all that is left is to charge the a/c, install decals, solve a vibration issue, put a few miles on the truck, and deliver it back to the owner for Christmas.
Short story version. Truck was a bone stock CST with buddy buckets. Had to clip the front half of the truck due to lots of cowl rot, replaced one cab corner and both rockers. Added the following: tach dash with guages, a/c, power steering, 5 speed transmission, alloy wheels, disc brake front end, aux battery, jump start kit, hydroboost, hydraulic clutch, chrome front and rear bumpers, blazer rear tank, hidden hitch, and probably a few things I am forgetting.
If you are interested in the build pics, head over to the 4wd project section.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 12-01-2009, 01:45 AM   #2
Musclerodz
Re: Great Pumpkin 95% done. 68 K20 nut and bolt rebuild
more pics.....
Mike Redpath
Old 12-01-2009, 01:46 AM   #3
Musclerodz
last ones for now
Mike Redpath
Old 12-01-2009, 01:50 AM   #4
project 67 sub
project 67 sub's Avatar
what the heck is the thing in the grille?
project 67 sub is offline   Reply With Quote
Old 12-01-2009, 02:29 AM   #5
Musclerodz
external jump start plug that a pair of jumper cables plugs into so you do not have to open the hood.
Mike Redpath
Old 12-01-2009, 05:37 AM   #6
NGN
NGN's Avatar
Very nice work you do, Truck looks great.
NGN is offline   Reply With Quote
Old 12-01-2009, 09:42 AM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Beautiful work Mike, that is one clean '68!
No interior shots???
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-01-2009, 10:20 AM   #8
i`m a self-bonified K/20 fanatic.so,I`m trying hard not to get all............ EXCITED ABOUT JUST HOW GREAT THAT TRUCK TURNED OUT!!!!!!
Old 12-01-2009, 10:27 AM   #9
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Did you put a hydroboost setup on that truck? Looks awesome by the way!
Tom Vogel is offline   Reply With Quote
Old 12-01-2009, 12:01 PM   #10
rwolf9653
more ideas than money
rwolf9653's Avatar
Looks great. How will you ever be able to let it go after all of the hard work you put into it??
Oh yeah, besides the cash.
Randy
1948 Chevy 3100 5 window
1966 Chevy C30 Dually
1967 Chevy K10
1972 Chevy K20
1972 Chevy C10
1972 Chevy K5 Blazer
1987 Chevy V10
2003 Chevy Suburban
rwolf9653 is offline   Reply With Quote
Old 12-01-2009, 12:35 PM   #11
pickupman
pickupman's Avatar
looks great, luv them 68's 4wd
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 12-01-2009, 12:53 PM   #12
big_al_71
big_al_71's Avatar
Very nice indeed,,I am digging the gas filler neck
I only like LWB in a 4wd and this one is awesome...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-01-2009, 01:29 PM   #13
Musclerodz
Interior still needs horn button and decals installed. Will take those as soon as they are installed
Mike Redpath
Old 12-01-2009, 01:30 PM   #14
Musclerodz
yes it is hydroboost for a 74 one ton. Made the plate to install, not a bolt on deal
Mike Redpath
Old 12-02-2009, 01:32 AM   #15
kgt
more info on the hydroboost please, i bought the unit assy already and i am going to install it on my 68.. thanks!
kgt is offline   Reply With Quote
Old 12-02-2009, 11:00 AM   #16
QKENUF4U
QKENUF4U's Avatar
awesome work but still got a rusty brake master ????
QKENUF4U is offline   Reply With Quote
Old 12-02-2009, 12:56 PM   #17
Musclerodz
Made the plate to bolt to the firewall, was not a direct bolt in. I had to make a rod extension and enlarge the hole in the firewall. Stock unit for a 74 chevy one ton
Mike Redpath
Old 12-02-2009, 12:58 PM   #18
Musclerodz
it is a new unit I did not painted since if it got brake fluid spilled on it, it may strip the paint if it was not cleaned soon enough. There is a few other parts on the truck (new MOOG suspension pieces) not painted either. None of it was painted orginally either.
Mike Redpath
Old 12-03-2009, 11:05 PM   #19
69TowRig
Amazing work. Very nice!
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 12-04-2009, 01:34 AM   #20
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Very nice build! Paint usually doesn't like to stick to master cylinders unless you use chemical resistant paint.
Ryan
1969 Chevy milk truck
