Old 12-09-2009, 08:10 PM   #1
57larry
Re: Radiator Shroud
I"m confused-------why do you put a V8 in the 6 cyl mountholes? are 6 cyl and V8 mounts different sizes ?
57larry is offline   Reply With Quote
Old 12-09-2009, 08:42 PM   #2
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Re: Radiator Shroud
The v6 and I6 motor stands sit in the rear mount holes, while the v8 stands sit in the front set of holes. My small block is in the 6 cyl mount location. This is because when I swapped out the 351 V6 I didn't want to move the transmission, lengthen the driveshaft, etc. I suspect that the others prob swapped out I6's since they are more common. To solve my fan distance issue I am in the process of mounting up a 16" e fan/shroud combo out of summit with a thermostat.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 12-09-2009, 09:33 PM   #3
jaros44sr
jaros44sr's Avatar
Re: Radiator Shroud
Originally Posted by dazza View Post
I was just scanning some other posts and found some saying the fan blades need to be half-in, half-out of the shroud. Is that for the stock fan? Should this be mounted at the back edge of the shroud?
Looks as if everybody that posted pics of their mopar e-fans has them dropped in a few inches.
Had no reason to mount it where I did, but I have noticed a small amount of cavitation. Plan to mount a speed controller to see if that helps
Originally Posted by 425HP409 View Post
If I was putting an electric fan in the shroud, I would put it at the rear edge fo the shroud for optimum performance.
You seem to have some knowledge on the subject, why do you state moving the fan out will work
Originally Posted by Gene View Post
What about HEI? Will it still fit?
Tight, but it will fit, but my dizzy has the coil in the cap
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-10-2009, 01:25 AM   #4
dazza
dazza's Avatar
Re: Radiator Shroud
ok, I used shorted brackets which brought it back a bit. The brackets hold it very securely, however when I put 3/8" of sponge-rubber weatherstrip around the outside edge, I thought I was going to need a huge press to get it in! Finally with a bit of clamping I got it to set perfectly. It would be a struggle to get it out... so hopefully this will keep temps correct. Shouldn't be to bad if I need to go back to the original, best of all - NO HOLES IN MY SHROUD!!
I fired it up she's definitely a sucker! Hard to tell how loud it will be in the truck, a little loud now but it's very quiet around here.
Any idea what the cfm rating on this fan is?
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 12-10-2009, 01:48 AM   #5
jaros44sr
jaros44sr's Avatar
Re: Radiator Shroud
Nice work! Don't know the CFM, but I do know mine really SUCKS Are you going to install a relay? Supposedily, these can pull 80 amps at start up
SAFETY FIRST
AS usual, off topic
Jim
