Old 12-18-2009, 04:57 PM   #1
trivejb
Will the bell housing from a I6 fit a 350
I currently a 68 C-20 with the 250 I6 with the heavy duty clutch and a Saginaw 3 speed (on the tree) with the R-10 overdrive unit. I have run across a nice 'built?' 350 from a Camaro that was an automatic. What parts from the I6 can I use? Such as bell housing, flywheel, clutch disk/pressure plate assembly (which I would replace with new). What problems might I encounter? Want to keep the Saginaw OD unit. Thanks for any help.
trivejb is offline   Reply With Quote
Old 12-18-2009, 05:34 PM   #2
LONGHAIR
Re: Will the bell housing from a I6 fit a 350
The bellhousing will definately work. I really don't know about the flywheel, but I would assume that the clutch parts would work if it had the right bolt pattern. Some had both patterns, others didn't
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 12-18-2009, 07:06 PM   #3
Wrenchbender Ret
Ifthe 350 is 85 on back, everything will fit.
Wrenchbender Ret is offline   Reply With Quote
Old 12-18-2009, 08:57 PM   #4
trivejb
Not sure at this point what year the 350 is but will check the serial numbers in the next couple of days to find out. Assuming that it is later than 85 what problems would I expect to have?
Old 12-18-2009, 09:12 PM   #5
bhoeger70
bhoeger70's Avatar
If it is a two piece rear main seal on the 350 everything will work even the radiator.Tto use a radiator shroud you will need to use one for a 4X4 because the engine sits back a few inches when you bolt it up to the 6cyl mounts. If I remember right you will also need to modify the ball stud for the clutch linkage some but it is not much, or hard to do.
"Beer is proof that God loves us and wants us to be happy" Ben Franklin
67 Chevy 1/2 lwb, 67 GMC 1/2 lwb (parts)
bhoeger70 is offline   Reply With Quote
Old 12-19-2009, 07:09 PM   #6
Wrenchbender Ret
86 up you will need to use a flywheel to match the engine. It has a built in counterweight.
Old 12-20-2009, 08:50 PM   #7
trivejb
Thanks for all the quick responses. Still working on the motor deal and now that I have these answers it helps me know what to expect should it work.
350 swap, inline6
