Old 12-24-2009, 02:20 AM   #1
weeble
weeble's Avatar
Lowering my 71 c-10 with leaf spring rear end
I want to lower my 71 c-10, but it has a leaf spring rear and the only thing Ive found so far is to buy new springs from CPP. but tht would set me back $400.Id like to drop the rear 4". Has anybody else done this and if so what did you use? Also someone told me that its rare to have leaf springs on a c-10 2wd, Is this true? Thanks for any help
weeble is offline   Reply With Quote
Old 12-24-2009, 02:23 AM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Lowering my 71 c-10 with leaf spring rear end
You can have your springs de-arched by a shop, or try removing a few leafs. You can also use shackles to lower it by 2".
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 12-24-2009, 02:29 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
ECE (Early Classic Enterpises) also sells a drop leaf spring and a drop shackle.
Old 12-24-2009, 09:43 AM   #4
Normy71
You can do a flip kit
check out his http://67-72chevytrucks.com/vboard/s...d.php?t=319981
Rolled the dice and lost!!
Check Out my 71 build
http://67-72chevytrucks.com/vboard/s...d.php?t=375158
Normy71 is offline   Reply With Quote
Old 12-24-2009, 11:37 AM   #5
echo72
echo72's Avatar
Brakes and Suspension related FAQ's will get you headed in the right direction. See link below:
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Every day is a challenge. Keep on truckin!
1972 Chevy Cheyenne LWB 350 engine TH400.
echo72 is offline   Reply With Quote
Old 12-24-2009, 11:41 AM   #6
bowtie72
bowtie72's Avatar
Axle flip would probably be cheapest. Leafs aren't as common as coils in 2wd most people say all GMC's are leaf and Chevys are coil I have found that not to be true. I have a 68 GMC with leafs and its lowered with a axle flip and C-notch.
1968 SWB "Little White Truck"
1972 LWB LS 4l80 "Plain Jane!!"
bowtie72 is offline   Reply With Quote
Old 12-24-2009, 01:18 PM   #7
nastyc10
nastyc10's Avatar
I did a flip kit when I had leafs and it gave me about a 5 inch drop. While I had it apart I added 1.5" drop shackles and a c-notch too. Its bagged now.
nastyc10 is offline   Reply With Quote
Old 12-24-2009, 05:52 PM   #8
mixermike
mixermike's Avatar
do a flip kit ..best bang for the buck..i put one on my 2000 gmc and my 1972 chevy lwb (my chevy has leaf springs)
mixermike is offline   Reply With Quote
Old 12-24-2009, 07:45 PM   #9
weeble
weeble's Avatar
Thanks for all the ideas, Ill probably do the flip but Ill check out all your suggestions Thanks
Old 12-24-2009, 11:58 PM   #10
Orange71shorty
I bought the lowered leafs for my 71 cheyenne. They are not re-arched, instead they use a reversed eye on the rear. I also took the helper spring out.The wheel wells are exactly 30" from ground to center of wheelwell with 275/60/15. They fit perfect. Hope this helps
Orange71shorty is offline   Reply With Quote
