Old 01-04-2010, 08:56 PM   #1
lnwlfbsktbll
lnwlfbsktbll's Avatar
Re: 3.07 gears????
I picked up a 12 bolt from a '77 truck to go in my '87 and the axle code shows it has 3.07s
'87 SWB GMC LY6/6L90E
'70 JEEP CJ5... My new toy
'06 Hyundai Accent... DD
Build thread located at http://67-72chevytrucks.com/vboard/s...5708&posted=1#
lnwlfbsktbll is offline   Reply With Quote
Old 01-05-2010, 08:50 AM   #2
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
does anyone know what i need to change my gears to either 3.73 or 4.10 they are 3.07 at the moment do i just need the ring and pinion set or a carrier too? its open and im leavng it that way !!! i know there other need parts to buy ?
78-5.3 is offline   Reply With Quote
Old 01-05-2010, 09:28 AM   #3
68 TT
Still plays with trucks
68 TT's Avatar
Re: 3.07 gears????
If is is a 2-series carrier like I think it is then you will need a different carrier too. If they break it down like the car 12-bolt carriers you will need a 3-series for 3.73's and a 4-series for 4.10's unless you run special thick gears on a 3-series carrier then you can get 4.10's on the 3-series. Can't get 3.73's on a 4-series carrier.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
68 TT is offline   Reply With Quote
Old 01-05-2010, 10:39 AM   #4
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
understand !!12 bolts are alot of hassle compared to a 9" i think i might start looking for a nine inch thats been narrowed down too around an s10 width for my future 4 bar set up i just wanna run lower gears till then!! these diesel gears are terrible
Old 01-05-2010, 01:49 PM   #5
68 TT
68 TT's Avatar
Re: 3.07 gears????
It sounds like the truck 12-bolt did not have a 2-series carrier like the car 12-bolt so you just need to find out where the gear ratio break point is for the carrier you have. A gear listing catalog would tell you.
Old 01-05-2010, 09:04 PM   #6
LONGHAIR
Re: 3.07 gears????
Wow, how many hi-jacks can we have in one day?....LOL
78 5.3
Yes you do need a carrier too.....and a professional to install it all for you. It's just not worth the time/effort and new tools required to do this "one time" job.
68TT
They don't....The break in the carriers is at 3.73. The 3.73 gears fit on a 4 series carrier and 3.42 is the lowest for the 3 series.
Pyrotechnic
If you have a 3 series carrier, you can buy aftermarket thick gears that will let you run 4 series gear ratios on your 3 series carrier.
Yup, but I'm not a big fan. IF they still make them, there are ring spacers too, not a fan there either.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 01-05-2010, 09:20 PM   #7
78-5.3
78-5.3's Avatar
Re: 3.07 gears????
ok so i will need a 4-series carrier for my 3.07 !!! out of a truck !!! to make it a 3.73
