Old 01-06-2010, 07:25 PM   #1
blackdiesel
blackdiesel's Avatar
Re: '55Chevylover's 55stepside build up
i sure hope you did the primer that POR said to use! i put just the paint on a very clean bare steel frame of mine several years ago and that crap came off in big sheets. Hope you dont have the same problems... But i sure wont EVER use that crap agian
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 01-07-2010, 11:36 AM   #2
'55Chevylover
'55Chevylover's Avatar
I put it on bare metal like the can said. I also sprayed undercoating on top of that. I sure hope I don't experience the same thing you did.
God Bless America
'55 Shortbed Stepside
'79 C10
2010 Malibu
Not too proud of: 2011 Nissan Altima, (Not American made)
'55Chevylover is offline   Reply With Quote
Old 01-07-2010, 01:27 PM   #3
blackdiesel
oh dear. Give it a few years
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-07-2010, 03:12 PM   #4
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
It's all in how you prep the metal, if you grind or clean all the rust off and don't use the prep solution it will peel, if you give it something to hold on to it will last a long time and you can paint over it.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 01-07-2010, 03:20 PM   #5
blackdiesel
Tri5
My frame was freshly sandblasted. if i would have known i would have just used a catalized paint. instead of a just brush it on straight out of the can paint....
Or if i would have sprayed it down with water and let it set a day or two to let it build up a layer of surface rust it would have been ok. POR stands for Paint Over Rust, which is what its designed to do. not POCM
on all my other projects i use a black acrylic enamel. havnt had any problems with the last 3 or 4 done that way.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
Old 01-07-2010, 05:09 PM   #6
Tri5Nerd
Tri5Nerd's Avatar
You are correct about painting over rust, they say to lightly brush the heavy rust off, not all rust then prime with their eching primer, then brush on, they really don't recommend spraying.
Tri5
