Old 01-09-2010, 01:53 AM   #1
198plus
198plus's Avatar
Cab Bolt Torque Specs
Anyone know the proper torque for the front and rear cab bolts using rubber bushings ?????
198plus is offline   Reply With Quote
Old 01-09-2010, 11:57 AM   #2
198plus
198plus's Avatar
Re: Cab Bolt Torque Specs
Bump.......Anyone ?????????
Old 01-09-2010, 01:03 PM   #3
62gmc910
62gmc910's Avatar
not spec to cab bolts but 1/2 -13 grade 5 (3slashs) 55 - 75 ft lbs. I would try 60 with lock tite for long term install or antiseize for short term
you should feel metal to metal contact as the spacers load up to each other
62 GMC 910 short fleetside 454 super t10 14 bolt
w/gov lock 70s c20 front discs (built in the 80s)
65 GMC 930 dualwheel 292 4spd all origonal 39k mi(my sons truck)
63 GMC 950 camperized school bus, (Gus the bus)
350 4speed 2 speed rear
64 GMC 950 "spare" bus 283? 4speed detroit locker
53 GMC 1ton dual wheel bus
78 GMC c25 short course off road race truck(son's truck)
355 th400 14 bolt (www.wheel2wheel.ca)
88 Peterbilt 379 longhood (hauls race truck)
62gmc910 is offline   Reply With Quote
Old 01-10-2010, 09:24 AM   #4
lakeroadster
I just installed a set of cab mounts on my 65 C10 a couple months ago. They came with cad plated bolts and nylon lock nuts. No torque spec's were listed, which is typical if nylon locknuts are used.
lakeroadster is offline   Reply With Quote
