Old 01-12-2010, 09:20 AM   #1
novafrog
novafrog's Avatar
a arm bushings
any tor. spec., i was going to tightin all i could,give shot of lube,thanks for any help
novafrog is offline   Reply With Quote
Old 01-12-2010, 01:37 PM   #2
425HP409
425hp409
425HP409's Avatar
Re: a arm bushings
Could you be a little more specific as to what you are trying to accomplish or what your problem is?
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Old 01-12-2010, 01:51 PM   #3
kevncar
Active Member
kevncar's Avatar
Re: a arm bushings
I think he's looking for torque specs on the upper and lower screw-in a-arm bushings...I have some I need to put in soon too...good question. I have the chassis service manual at home. I'll look tonight to see if it says anything.
Kevin
72 Chevelle
67 C10...454/TH400
Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961
kevncar is offline   Reply With Quote
Old 01-12-2010, 05:50 PM   #4
novafrog
novafrog's Avatar
Re: a arm bushings
that is what iam doing thanks
Old 01-12-2010, 06:47 PM   #5
dfwright
dfwright's Avatar
Re: a arm bushings
I don't know if it is different for the different years, but for 72, it is 95 upper, 130 lower
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 01-13-2010, 09:11 AM   #6
novafrog
novafrog's Avatar
Re: a arm bushings
72 thats what i have,thank all of you for help
Old 01-13-2010, 10:23 AM   #7
425HP409
425hp409
425HP409's Avatar
Re: a arm bushings
Make sure that you pregrease the bushings and shaft if you are installing new bushings as the clearances are "Very Tight" and it is hard to grease them with a grease gun when they are new.
Charles
90 ZR1 Corvette
Old 01-13-2010, 08:46 PM   #8
novafrog
novafrog's Avatar
Re: a arm bushings
thanks you all have been very helpful
