![]() Join Date: Jan 2008
Re: torsion bar "lowered" help
Yes I remember that post. It stated to pull the torsion out and rotate it "this far" I assume you would rotate it so that it would initially have less spring rate so you would then have to tighten your bolt up further in order to achive some type of spring rate. Since you rotated it whatever distance in the tightest setting you would be lower than factory height. Yet I also read that someone tried this and it did not work for them..but did they rotate far enough.. I would make sence that it would work.. I although have not tried..
Reid Last edited by 72bigred; 01-24-2010 at 01:30 AM. |
#2 | |||
But Found Her 25yrs Later!
http://67-72chevytrucks.com/vboard/s...48#post2717748 Quote:
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 Last edited by LostMy65; 02-08-2012 at 03:07 PM. |
