Old 02-19-2010, 11:52 AM   #1
Tony@AirRideTech
Junior Member
Re: Installing a different size rearend
Dont forget about the panhard bar which the factory rear end has a bung cast onto the houseing.... you can always go to a weld on panhard bar but it has to be in there. If you are going to a different 10 bolt or 12 bolt, we do have a panhard bar bracket that relocates the bar further down to correct its positioning for a lowered ride height. The axle brackets are gravey... you could even get in touch with Mosier for some replacments to weld onto a different rear end.
Tony@AirRideTech is offline   Reply With Quote
