Old 02-17-2010, 08:45 PM   #1
72gmcshorty
72gmcshorty's Avatar
Difference between coils and blocks?
I am wanting to lower the back of my truck about 6". I know there are drop coils and drop coils plus blocks. Whats the difference between using just coils and coils plus blocks?
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 02-18-2010, 01:38 AM   #2
SCOTI
SCOTI's Avatar
Re: Difference between coils and blocks?
4" coils plus blocks allow running a standard length shock w/factory brackets. 6" drop coils alone are going to be too much drop & will typically require other mods: modifying the OE shock brackets; using 'drop' shocks; or replacing the OE brackets w/a shock relocator kit.
Of the trucks I've ridden in, 4" coils w/blocks rode better vs. 6" coils. They weren't 'apples to apples' set-ups (different manufacturer springs & shocks) so it's just a subjective opinion.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-20-2010, 07:54 PM   #3
sv10001975
sv10001975's Avatar
there are also so other advantages to using the blocks, but I have heard that the 4" spring and 2" block can cause some problems on a 15" wheel. you also get the advantage of keeping you instant center of you suspension in a better location vs. the 6" lowering spring. i have 6" springs and will changing to 4" springs very shortly. all i am waiting on is trying to confirm the 2" block and 15" wheel interference issue.
sv10001975 is offline   Reply With Quote
Old 02-20-2010, 08:30 PM   #4
SCOTI
SCOTI's Avatar
The 'interference' issue w/2" blocks is the bottom edge of the shock mount & u-bolts are just past the scrub line of the wheel. In the event of tire failure @ speed, there is a possibility of the mount or bolt contacting the road which can lead to loss of control.
1.5" blocks work w/15" wheels.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-20-2010, 09:23 PM   #5
sv10001975
sv10001975's Avatar
do you happen to know the length u bolt needed for the 1.5" blocks? this way I can go ahead order the bolts while I make my blocks.
Old 02-21-2010, 04:17 AM   #6
SCOTI
SCOTI's Avatar
I can go measure just as easily as you can. Put a tape to your current ones & add 1.5". Done....
If there's some reason you cant measure yours, let us know.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-22-2010, 07:29 PM   #7
72gmcshorty
would 5" spring and 1" block have any issues?
1992 Gmc 2wd
Old 02-22-2010, 08:42 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
They might not have an issues, but I have found the more drop you can gain from "static" changes the better off you are. Ok, let throw a disclaimer and say in "most" cases.
What that means is try for the best option other than spring drop. Anything more than a 2" spring up front and a 4" spring in the rear and the ride quality starts to degrade.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 02-22-2010, 08:51 PM   #9
robzilla
robzilla's Avatar
does anyone have some pictures of the setup? i'm looking to do the same with blocks and coils.
thanks
robzilla is offline   Reply With Quote
