Old 02-24-2010, 04:12 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
71/72 throttle linkage
I bought a gas pedal conversion plate from LFD to switch over my 70 gas pedal to the 71/72 set up. I have found the pedal assembly but do not have the cable that hooks it up to the carb linkage. Does anyone have a Napa part number for this or is it a LMC item?
Also it is missing the stainless steel surround. Can you still get those?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 02-24-2010, 04:27 PM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 71/72 throttle linkage
might want to order up the lokar cable setup...seen a couple guys do this and it looks good....check with member 'sinister' and 'hart rod' they both have done a little write up on it too...I'll see if I can find the thread
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 02-24-2010, 04:32 PM   #3
BLACK AND BLUE 67-72
Firefighter
BLACK AND BLUE 67-72's Avatar
Talking Re: 71/72 throttle linkage
610-1417 24" LONG
610-1426 21.375" LONG
Both are Napa Numbers.
'72 Chevy SWB 350 Auto
'67 GMC LWB 350 4 speed
'70 Chevy 4x4 Stepside 350 Auto
Yellville, Ar. USA
BLACK AND BLUE 67-72 is offline   Reply With Quote
Old 02-24-2010, 07:19 PM   #4
lts70
1970 Daily Driver
lts70's Avatar
I have a Edelbrock 650 performer carb. Do you think I will need the 24" or 21.375" long cable?
I tried seaching for the lokar linkage but had no luck. I bet the look good.
Old 02-24-2010, 07:36 PM   #5
Sinister
Between Trucks...
Sinister's Avatar
The Lokar stuff is spendy, but I had to go with it because I had a Lokar kickdown setup already . Here's a link with pics: http://67-72chevytrucks.com/vboard/s....php?p=3810086
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 02-25-2010, 10:47 AM   #6
lts70
1970 Daily Driver
lts70's Avatar
Do I need to buy anything besides the cable to run the stock cable set up? Like any brackets that bolt to the manifold to hold the cable from moving? I still can’t find any info on what length I need as well. Any help would be appreciated.
Old 02-25-2010, 11:08 AM   #7
Sinister
Between Trucks...
Sinister's Avatar
You'll need a carb bracket. Don't know if those lengths listed are housing or cable lengths. Can't help there. It'll depend on your setup, intake, carb, motor location. The nice thing about the Lokar setup is it's custom fit and adjustable. I used a 24" Lokar cable and had to cut it down to size. Good luck.
Beat it to fit,
Old 02-25-2010, 12:01 PM   #8
Hart_Rod
Hart_Rod's Avatar
I've got an extra cable I'll send to you for $10. LMK
Hart_Rod is offline   Reply With Quote
Old 02-25-2010, 12:52 PM   #9
Camaro_nut2001
Chevy Lover Till The End.
Camaro_nut2001's Avatar
Hello Hart_Rod, if he doesn't want or need the cable I could use it on my upgrade that i'm doing. Thank you
1969 Chevy SWB Big Block - Under the knife as of 12/26/2011
1989 Chevy Silverado, 4X4 - Daily Driver
1996 Chevy Suburban K1500 - 4-Wheeler, Campin Truck
1968 Chevrolet Impala Sport Coupe - 327/350hp, TH400, all original.
Members I've met: BamaBaxter,
My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=500359
Camaro_nut2001 is offline   Reply With Quote
Old 02-25-2010, 01:17 PM   #10
Hart_Rod
Hart_Rod's Avatar
I've got 2 of them.
Old 02-26-2010, 02:17 PM   #11
lts70
1970 Daily Driver
lts70's Avatar
Does that include the carb bracket and shipping?
Old 02-26-2010, 02:23 PM   #12
Hart_Rod
Hart_Rod's Avatar
No carb bracket. Add a couple $ for shipping.
Old 02-26-2010, 04:20 PM   #13
72K20
Slow Old Timer
I'll take the other one if it's still available? Moved my engine forward when I put in the 700R4 and have been goofing with throttle cables ever since.
72K20 is offline   Reply With Quote
