Old 02-24-2010, 04:46 PM   #26
CPPJEFF
Re: Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
Originally Posted by dwhitley167 View Post
does anyone actually have a before and after pic of the set up, and possibly a pic of the bottom side of the bracket? would be great to see, thanks
No i just have the pics i listed.
CPPJEFF is offline   Reply With Quote
Old 02-24-2010, 05:21 PM   #27
vegaschevy
Jeff,
I just need the upper mounts as I have porterbilt arms,
what kind of price on just the uppers and bolts?
vegaschevy is offline   Reply With Quote
Old 02-25-2010, 08:53 PM   #28
vegaschevy
Bump...
Old 02-26-2010, 11:54 AM   #29
CPPJEFF
Originally Posted by vegaschevy View Post
Bump...
I sent an e-mail to my engineer trying to get just uppers, im sure we can do that.
Old 02-26-2010, 11:59 AM   #30
vegaschevy
Excellent to hear!!!
Old 02-26-2010, 01:10 PM   #31
SCOTI
SCOTI's Avatar
I sent an e-mail to my engineer trying to get just uppers....
Is this like going to a car lot & the sales guy says "let me check w/the mgr..."?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-26-2010, 02:32 PM   #32
DKN
Active Member
Not in this case. Some parts are only built/purchased in kits. If that was the case then the cost for the partial kit is going to be more than the complete kit; we have to do extra work to ship the modified kit to the correct customer. In this case I have these unassembled and can get Jeff the modified/different kit; Jeff will then need to babysit the kit thru the shipping process in order to prevent shipping a regular kit or having this different kit go to someone else. So it's not exactly that easy to do somthing special/different and the cost savings is not very much.
Danny Nix
CPP
DKN is offline   Reply With Quote
Old 02-26-2010, 03:03 PM   #33
CPPJEFF
Here is a better way to explain it. You are on that car lot and your boss tells you to sell all the toyota's for $15,000 and out of nowhere one customer just needs the rear half of the car and salesman still wants to help customer but needs further guidance as he is not familiar with that territory.
Old 03-12-2010, 05:04 PM   #34
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
It's tough to get my head and camera under there but here are some before pics with a 4" drop springs. If you can't tell the shocks are almost lying down.
With the new brackets the shocks sit much more upright.
In the ride department, I went from full compression to full extension over speed bumps and hitting pavement cracks on the freeway at speed. It actully feels like I have suspension now.
Hard Luck is offline   Reply With Quote
Old 03-12-2010, 05:52 PM   #35
CPPJEFF
Good pics. Thanks
Old 03-12-2010, 06:23 PM   #36
SCOTI
SCOTI's Avatar
Good pics. Thanks
The key detail the relocators show is the pics is increased travel range.
Look @ the initial pic & you can see the upper/lower shock housings (1st pic). Just under the edge of the upper shock housing you can see a silver colored decal on the lower housing. Notice the distance is greater between w/the two w/the relocators installed (3rd pic)? Same shocks w/more travel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 03-12-2010, 06:28 PM   #37
CPPJEFF
Yes that is 100% correct!
Old 03-14-2010, 04:40 PM   #38
dwhitley167
dwhitley167's Avatar
awsome pics, thanks. i def need to get a set of those pretty soon.
67 chevy 402 BB w/ TH400
Learning as much as i can before i dig in!!
dwhitley167 is offline   Reply With Quote
Old 03-15-2010, 10:58 AM   #39
CPPJEFF
Let me know i have plenty in stock. Thanks
Old 03-17-2010, 02:09 AM   #40
Super73
Super73's Avatar
Jeff,
Any reason you are no surrounding the lower shock hole with some metal on both sides for the bolt to pass through?
I think you you guys recently released a piece that fixes that issue for the front upper shock hole where it connects to the frame. One would think over time it would fail like the front upper on does.. Just food for thought.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 03-17-2010, 10:44 AM   #41
CPPJEFF
Originally Posted by Super73 View Post
Jeff,
I will send this post to Danny and see if he wants to take a stab at it. Thanks
Old 03-19-2010, 08:41 PM   #42
DKN
Active Member
Jeff,
Unlike the frame where the factory stud is atached in the front, this bracket is THICK. We made the part from 1/4" steel. We have not had any problems with stud bending the bracket.
Danny Nix
CPP
Old 02-11-2013, 10:15 PM   #43
ob1monkey
Man this thread is old, any chance your still offering these to members for 50?
ob1monkey is offline   Reply With Quote
Old 02-11-2013, 11:12 PM   #44
Dano69c10
Dano69c10's Avatar
CPP Rear Shock Relocators are great!
I've had them on my ride for two years and they still look new!
Highly recommended. Heavily constructed.
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 02-11-2013, 11:43 PM   #45
cubber
Speedway has the CPP relocators for $59.99, just put mine on a few week ago!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 02-12-2013, 12:03 PM   #46
CPPJEFF
Hey guys i am still here for anything you need! Just call me 888-522-8303 ext 118
Old 02-12-2013, 01:55 PM   #47
Dano69c10
Dano69c10's Avatar
Jeff,
For this reason I was going to use a 60-66 stock lower shock set-up, but when I saw the construction of the cpp part, I didn't hesitate to use the cpp part.
Pic of 60-66 lower shock mount:
'69 Fleet
Old 02-12-2013, 02:17 PM   #48
CPPJEFF
Yeah with the stock mounts you just cannot get the correct geometry on the shock. Great picture!
Old 02-14-2013, 01:52 PM   #49
ob1monkey
Talking Re: Having the shocks relocated is the only way to fly!!CPP shock relocation kit!
Jeff your the MAN! thanks again for the hook up on parts. Always a pleasure doing business with you.
Old 02-14-2013, 06:42 PM   #50
CPPJEFF
Ain't no thang brutha!!
