Old 05-07-2003, 12:49 PM   #1
ocbaud
Garage Queen Material
295/50/15's on the rear?
i've decided that i'm not getting 255/60's all around. i want some meat in the back.
what i'm wondering is will a 295/50 tuck with a 6" drop on 8.5" wheels with i "think" about 4" back spacing.
will a 295 be to wide for a 8.5" rim?
ocbaud is offline   Reply With Quote
Old 05-07-2003, 12:51 PM   #2
TIMSPEED
TIMSPEED's Avatar
Re: 295/50/15's on the rear?
NOPE! That's what everyone's running around here, with dropped C10's. They all have 295/50 15's, but they have like 8" rims! It'll look pretty good Personally though, 255/45 18 would look better
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 05-07-2003, 12:53 PM   #3
ocbaud
the 295/50/15's are only .4" shorter than teh 255/60/15's . and thats fine, since my back end is a little higher anyway. the sidewall is only .2" shorter than the 255/60's too.
Old 05-07-2003, 12:57 PM   #4
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Technically...it really is to wide for it but if you dont care about wear/danger/ contact patch or bulging sidewalls go for it.
I know that tons do it and I dont care....its flat out too wide of a tire for that wheel...ask low84...he probably hates mounting tires like that on wheels that size. And the way the tire has to bend around the wheel..you end up with less tire contact patch on the road than you would with a 255 on the wheel.
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 05-07-2003, 12:59 PM   #5
TIMSPEED
TIMSPEED's Avatar
Yeah...look at me, I've got a 255 on a 9½" rim
See Them Here
Old 05-07-2003, 12:59 PM   #6
ocbaud
well your a pen0s head!
Old 05-07-2003, 01:08 PM   #7
LOHRTBT
LOHRTBT's Avatar
And you are how old eric?? lol...nevermind we can tell haha
Riptide has the right setup. 295 on a 10" wheel is perfect and looks much better while taking advantage of the full contact patch
~Dave~
Old 05-07-2003, 01:18 PM   #8
ocbaud
to tell you the truth, i'm not sure exactly what size my rims are. i do know the 275/60/15's fit on there perfect and do not look to wide or to skinny, but pretty much flush.
anyways. would a 305 tuck? what size rim would be best for a tire that size. i'm asking about it for a set of 18's btw.
Old 05-07-2003, 01:21 PM   #9
LOHRTBT
LOHRTBT's Avatar
Just stop screwin around and get some 335's!!
~Dave~
Old 05-07-2003, 01:26 PM   #10
TIMSPEED
TIMSPEED's Avatar
Eric, for the rears, get 275/40 18 on a 9½" rim with 5½" BS. Trust me, they'll fill the fenderwells up PERFECTLY.
See Them Here
Old 05-07-2003, 01:27 PM   #11
LOHRTBT
LOHRTBT's Avatar
YEP!
but I think Eric is confused....I think he is driving G's Tire Fryin machine and needs a 26" wide slick on the back for traction!! lol
~Dave~
Old 05-07-2003, 01:43 PM   #12
85 GMC
has anyone measured to see how much offset to the inside our trucks will except? , I have a 10" rim w/ 325-50's on mine with a 3.5 backspaceing , and to get them in the wheelwell all the way i would need aproxamatley a 4.5 backspacing. I have about 1/2" of sidewall out of the wheelwell.
just wondering
85
85 GMC is offline   Reply With Quote
Old 05-07-2003, 01:46 PM   #13
low 84
low 84's Avatar
yeah i definatly agree with dave. a 295/50 needs a 9.5 or 10 inch wheel to fit right, and get the benefits fromt the wider tire. but before you go stuffin some meats under there stuff some power under the hood. i'd much rather have to much motor for my tires than too much tire for my motor. i'm eventually gonna be running 15x7's on front with 215/70/15's and 15x10's on rear with 295/50/15's. those tire are the same hight but the back one is a hella lot wider than the front. but i stil don't think those will keep me planted
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 05-07-2003, 01:49 PM   #14
LOHRTBT
LOHRTBT's Avatar
Lets hope!!! hehe
~Dave~
Old 05-07-2003, 01:52 PM   #15
PHOENIX
I have the following:
Front: 15x8 Centerline Telstar w/ 4" BS w/ 295/50/r15's
Rear: 15x10 Centerline Telstar w/ 4.5" BS w/ 295/50/r15's
A 295/50/r15 is kind of wide for an 8" wheel.
They do fit and the sides do budge slightly.
The tire shops I have talked with said there is no problems with mounting that tire on an 8" wide wheel.
I tried to find different tires to get away from the slight budge, but didn’t have luck.
I wanted to keep the back tires, 295/50/r15’s, and just change the front to something not as wide.
But very few companies made tires in both sizes so I could have matching front and back.
That is why I kept the 295/50/r15’s all around.
These tires and wheels (front and back) will NOT tuck up into the wheel wells.
The edge of the tires are right at the wheel well lip.
Hope that helps some.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 05-07-2003, 04:48 PM   #16
AirMale
AirMale's Avatar
My set up:
Front- 20X8.5 w/4.75"bs running 255/35/20
Rear- 20X10 w/5"bs running 295/40/20
I too reccomend a 10" rim for anything over 275 wide. The set up I run works with bags with over an inch clearance on both sides of the rear wells.
86 SWB 9.0 LITER
T-400-OD 4.11 eaton-4/5 drop
Best 1/4 12.51 @112mph no traction
AirMale is offline   Reply With Quote
Old 05-11-2003, 10:51 AM   #17
85 GMC
took some pics of my 325's , outside and inside. theres alot of room to get the under there.
Old 05-11-2003, 10:53 AM   #18
85 GMC
and
Old 05-11-2003, 03:11 PM   #19
SCOTI
SCOTI's Avatar
85GMC, do you have the wheel specs (width/b.space)?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-11-2003, 05:26 PM   #20
85 GMC
15-10's with a 3.5 backspaceing , they are series 55 engles
Old 05-11-2003, 10:16 PM   #21
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The 255 will hold that the 305 pretty good. They hold mine really good when they are hot. If they are cold you can for get it. The 305 will light'em up! Without a 700R4 the 305 probably will not smoke anything bigger than the 275. :p
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 05-20-2003, 12:41 AM   #22
C-10volvo
C-10volvo's Avatar
wow, im running a 1984 305 with a 700r4. it has in 15'' by 7'' with 235 15 75's and that thing its already hard to powerbrake. then your saying that youve done it with 255's. am i loosing a lot of power somehow? or does that 55 series tire make a lot of difference? my truck has only 50000 miles on it!!! why??? maybe the new 572 will solve all my problems. 720 hp would get that moving along well.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 05-21-2003, 12:06 PM   #23
Gibble
mmmm....Rye and Coke
Gibble's Avatar
I'm running 275/60s in my 305 and it looks great, and amazingly it can still get the tires to chirp, with the cracked manifolds and all
Gibble is offline   Reply With Quote
Old 05-21-2003, 08:09 PM   #24
apstguy
LED King
apstguy's Avatar
I have 275/60s as well and they do work well for the 305s. I tempararily have 225/75 on and they spin like no one's business! My 305 can burn! Yesss!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 05-22-2003, 02:25 PM   #25
ol84
I am running 15x10 5 inch BS...295/50/15 and they tuck into my wheel well about an inch. I am running 15x7 in front with 255/60. The combo looks pretty good. I wish I had some pics to show.
1984 C10 SWB
Custom Frame
Blow Through Carb Single Turbo
Hope to be on the road by Summer 2018
1967 C10 CST LWB
327/PG Original
Running Driving Future Project
ol84 is offline   Reply With Quote
