Old 03-12-2010, 12:54 AM   #1
Slow Build
Slow Build's Avatar
Re: swap 64 gauges to 66 what is needed?
Quick question since we're on the subject of gauges. Other than the 5 screws on the front, what else needs to be done to get the gauges out? Found one at a junkyard and it wouldn't budge after removing the screws and I didn't want to stick my hands into the spiderwebs to feel around the back and didn't want to put my head on the gross carpet to be able to see the back.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-12-2010, 12:59 AM   #2
daverod
SSN 706
daverod's Avatar
I'm not sure how to do it just type it in on your search thing. It in the tech section.http://rmcavoy.freeshell.org/ Damn I'm good. Ok it was really easy. All this talk almost makes me want to finish mine. Maybe this weekend. The main reason I swapped was so I could put in a tech. Then I switched to a hei And I'm not sure how to hook it up.
daverod is offline   Reply With Quote
Old 03-12-2010, 01:05 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Also need to remove the speedo cable and the oil line going to the gauge. Probably some electric harness, too.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-12-2010, 01:14 AM   #4
Slow Build
Slow Build's Avatar
I figured that I could deal with that stuff once I pulled the gauges out of the dash a little, but with the screws out the gauges are still solidly held in the dash. I can't even pry them out a little bit with a screwdriver.
Sorry for the thread-jacking
Past GM Trucks:
Old 03-12-2010, 01:23 AM   #5
protrash64
protrash64's Avatar
I wonder if it's rusted on??? I would think that it would have some give.
Old 03-12-2010, 01:37 AM   #6
daverod
SSN 706
daverod's Avatar
Next time take a BFH with you. I'm pretty sure just the screws hold it in. It comes out towards you.
Old 03-12-2010, 01:58 AM   #7
Slow Build
Slow Build's Avatar
I think part of my problem is the ignition switch. Not stock and I can't get it completely out (thread issues) but I can't really move the gauges enough for that to even be issue yet. Before the BFH comes out of my tool bag I'll have to resort to laying on the gross carpet and get a good look at the back.
Sorry for the interuption.
Now back to your previously scheduled thread.
Past GM Trucks:
