03-15-2010, 10:53 AM | #501 |
Under Construction
Re: 1967 C10 Custom Big Window
Progress is progress, as long as its on the "Chev-a-dectomy-a-potomous-a-saurus-rex-da-dactile-orangeus-colorus-money-pitacus" , and not the self accelerating one!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
03-15-2010, 07:13 PM | #502 |
Sofa King Crazy!!
Here are the updates! A couple of pics of progress.
Installed my flywheel and drained my torque converter some so I wouldn't be pouring out trans fluid everywhere. Pulled out the dusty transmission and cleaned it up (cleaned and painted months ago) and butted it up to the engine. After 4 trips to the auto supply store I finally got the right trans mount. Got it in the frame rails with no problems, only took about 40 minutes. Took my time so I wouldn't scratch the paint! The brake booster is going away and will be replaced with a hydrobooster to clean things up. All was well until I attempted to fit the headers........no fit, back to searching for some shorties. Just another pic for your viewing pleasure. And another. The weight of the engine lowered the front down about an inch so with everything on the front installed it should sit right where I want it. Note the pictures hanging on the back wall of the shop! Also installed the seat so I could do a little imaginary cruising!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 03-16-2010 at 08:18 AM. |
03-15-2010, 07:34 PM | #503 |
You have to be itching to drive this. It's looking great. Hopefully ordering my paint this week.
67 C10 2wd Stepside (to be fleetside), Factory AC truck, Big Back Window, just got a 6.0/6l90e to jam in it now..... Needed: paint and lots of it. and i'm sure lots more misc. parts. Project 67 short step Build Thread 01 Sierra Crew 6.0 2015 Ford F150 Work gave me truck i really wouldn't buy a ford. |
03-15-2010, 07:57 PM | #504 |
VA72C10
Looks great man! Love it. A mix of the new and the old. Great style! Sorry bout the headers....which ones were they?
Looking for a 67-72 swb or blazer project in or around VA. |
03-15-2010, 10:10 PM | #505 |
Now that is what i am talking about!!!!!!!!!!!!!!!!!!!
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
03-15-2010, 10:58 PM | #506 |
low n' slo
woot!! thats what i like to see! looks great david
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
03-16-2010, 01:26 AM | #507 |
Looks great! I agree you have to be anxious to drive this truck!
03-16-2010, 07:35 AM | #508 |
Under Construction
Nice progress David... your getting closer each time.... Imaginary cruizing sounds fun!
03-16-2010, 08:30 AM | #509 | |||
Sofa King Crazy!!
Lookin better, gotta keep up with you! Still have so much to do on the engine, HEI, carb, headers, all the pulleys and belts and power steering, alternator.........does it ever end?!?!?! Quote:
Thanks Heath. It has been a long time just to get to this point, but worth it. Glad I slowed down on it to build it like I wanted.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-16-2010, 09:53 AM | #510 |
67cheby
Looking Awesome !!!
03-17-2010, 09:22 AM | #511 |
Sofa King Crazy!!
03-17-2010, 08:13 PM | #512 |
Sofa King Crazy!!
This pic shows how much the c-notch helped and how low it sits in the rear now. I am almost 5'11'' and the top of the cab sits level with my shoulder. Picture credit goes to my girlfreind Christy.
03-17-2010, 08:22 PM | #513 |
VA72C10
Looking great. Yeah, I was loading parts into my bagged longbed (sitting on the bagged frame) and it was so nice to be able to drop them over the side of the bedsides with no problem because it's so low....
03-17-2010, 08:28 PM | #514 |
VA72C10
From no tuck
to tuck
03-17-2010, 10:11 PM | #515 |
Sofa King Crazy!!
Yeah! You can see I gained.....uh lost at least two inches! Made a big difference with the notches.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 03-17-2010 at 10:13 PM. |
03-17-2010, 10:32 PM | #516 |
Under Construction
nice work David!
03-18-2010, 09:51 AM | #517 |
67cheby
looking awesome man
03-18-2010, 02:26 PM | #518 |
David, your truck makes me jealous, yours is painted and looking good, mine runs but is nowhere near done, if ever! Keep it up, you are doing a great job, btw, I will get you do do a sketch of the camaro, pm you later.
03-18-2010, 06:51 PM | #519 |
Man! That's looking great! I'm really diggin' the air cleaner.
72 Suburban 3 Door http://67-72chevytrucks.com/vboard/s...d.php?t=265728 family fun cruiser 71 Cheyenne Project http://67-72chevytrucks.com/vboard/s...d.php?t=299232 Almost finished 93 Silverado http://www.67-72chevytrucks.com/vboa...d.php?t=378258 Flamed, bagged, body dropped on 22's 98 Chevy short bed DD 97 Z71 3 Door 51 Suburban-S-10 swap "What other hot rod can you carry 7 of your friends in" |
03-18-2010, 10:00 PM | #520 |
Sofa King Crazy!!
Oh yeah, can't say I have ever seen another so I'm diggin it too!! Thanks bro!!
03-19-2010, 01:06 AM | #521 |
Man bro, that truck is looking sweeet! I knew the engine scoop mod would look bad ass!...Good job!...
03-19-2010, 11:34 AM | #522 | |
Sofa King Crazy!!
Can't wait to gitter done!
Thanks for the compliments! When I have people like you and James and Heath saying that, it must be coming out alright for my first build. That scoop was a true brainfart, but I must say it was a cool idea and I thought it would be original. Gotta figure out a good way to attach it to make it look like it's "floating" on top of the motor.
03-20-2010, 09:22 AM | #523 |
David, what are you using for an air cleaner. that will really make or break the bank for mounting it.
03-20-2010, 05:23 PM | #524 |
Sofa King Crazy!!
I am using a 6.5 inch round Mr. Gasket that I will probably have to cut down about 1 inch (maybe). The scoop is about 2.5 inches from the top to bottom and the cleaner is about 4 inches tall. The scoop is about 14 inches wide. I am thinking of using a little longer stud for my carb and making 2 braces one for the front and back that will hold the scoop just about .25 of an inch above the air cleaner. Bolting it to the carb studs should be sturdy and installing and removing should not be too hard.
03-20-2010, 08:56 PM | #525 |
Still Learning
Looking good! You'll be on the road in no time.
Tags |
1967, custom, lwb |
