03-13-2010, 05:19 PM | #1 |
Should I get an extra frame?
I've got a complete '50 truck but I am a big fan of efficiency (lazy) and space is limited with a 3 car garage. There is an extra frame locally for next to nothing, I was thinking about bringing it home and starting with it first. I wouldn't have to have a truck blown all apart in my garage and yard and when the frame is done I could just swap the body over. Plus I'm sure the frame would fit in the garage now. Anybody done this? What are the advantages/disadvantages?
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-13-2010, 06:04 PM | #2 |
Insane In The Membrane
Re: Should I get an extra frame?
Advantage: Easy restoration like you stated.
Disadvantage: Frame and body VIN numbers won't match. |
03-13-2010, 06:21 PM | #3 |
I'm not sure there are any #'s on the AD frames?
03-13-2010, 07:08 PM | #4 |
A320 Pilot/USAF Retired
I'd do the extra frame!
JJ My 1957 build: http://67-72chevytrucks.com/vboard/s...d.php?t=334552 http://www.trifive.com/forums/showthread.php?t=22037 Instagram - Chuckdriver57 |
03-13-2010, 07:43 PM | #5 |
and a few others
Does that frame still have the front axle on it? They're worth a few dollars to anyone building a fenderless rat rod.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
03-13-2010, 09:05 PM | #6 |
The axle is off but he's got a whole stack to choose from, maybe I should buy them. Does anybody know how much are good doors and fenders worth?
03-13-2010, 09:18 PM | #7 |
Cancer Survivor in the making.
The only numbers on a '50 are on the serial number plate in the driver's door opening. There are none on the frame or any other part or at least GM didn't put them anywhere else.
My '54 GMC project is based on a frame swap. I'm doing all my modifications on one frame while all the sheet metal still sets on the original frame. With a little fussing the sheet metal donor is still driver enough to be moved around the yard so its handy this way. Cabs and beds that have been separated from the frame and running gear are harder to move around. I have one setting on my trailer right now because I can't decide where it should be stored long term.
'55 1st GMC Suburban - '54 GMC 1-ton trailer puller (in process) - '54 GMC 1-ton Hydra-Matic - '47 Chevy AD COE and lots more rusty old iron. Steve@OldSub.com OldSub.com . MaxwellGarage.com . OldGasTowRigs.com |
03-13-2010, 09:21 PM | #8 |
03-14-2010, 07:23 PM | #9 |
That was my choice and it worked out great, until I started cleaning things and from there it got wAY OUT OF LINE!!!
03-18-2010, 03:39 PM | #10 |
Ok, so I decided to go get the frame. I looked at mine again and it is solid but has heavy pitting which I hate. His frame is in better shape.
So does anybody local want to tag along or need fenders, doors, axles, hoods, a cab, core supports etc..? He's got a barn full, probably 10 trucks parted and stacked. Cheap, too.
03-18-2010, 10:41 PM | #11 |
See if he can load them up and bring them up here and I'll go with you. Dang it!
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
