Old 03-30-2010, 01:00 AM   #1
c10seconds
c10seconds's Avatar
WTB column shift cable/linkage components
I just switched from a floor shifter to a column shifter and now Im in need of any other parts required to make it work. If you have something that will help me, let me know. Thanks
c10seconds is offline   Reply With Quote
Old 03-30-2010, 03:09 AM   #2
mosesburb
I had a V-8
mosesburb's Avatar
Re: WTB column shift cable/linkage components
What year and is it 2x or 4x??
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
Old 03-30-2010, 03:09 PM   #3
c10seconds
c10seconds's Avatar
My truck is a 67 c10 2wd Big block/TH350
Old 03-30-2010, 04:02 PM   #4
mosesburb
I had a V-8
mosesburb's Avatar
Hmm, I have some 4x stuff, but that will do you no good.
Send tkorinek a PM on here. He should have everything you need.
Old 03-30-2010, 05:44 PM   #5
MARIOS68PANEL
Active Member
MARIOS68PANEL's Avatar
I have the shifter linckage from the column to trans. I will get a picture in a few.
Here , is this what your looking for? $10.00+shipping
67 short step
71 Custom
MARIOS68PANEL is offline   Reply With Quote
Old 03-30-2010, 06:12 PM   #6
c10seconds
c10seconds's Avatar
I have no idea what its supposed to look like. What is this out of?
Old 03-30-2010, 07:46 PM   #7
MARIOS68PANEL
Active Member
68 with th35o . little end goes in the steering column shifter and the other end goes to transmition shifter . L shaped part goes through the u shaped bracket on the trans shifter and the other end sticks into the mount on the frame. You need a spring that can be picked up at your local parts store that keeps it pushed towards the trans . you will need a washer and clip to hold the L shaped end in the trans shifter. I dont have any pictures or I would post one for you.
67 short step
71 Custom
Old 03-30-2010, 09:23 PM   #8
teeitup
Just like to part out trucks!!
teeitup's Avatar
here is a th350 setup, I have one guy that I have to show it to, if he doesn't want it. Its $30 plus shipping, you can kind of see it on the top left
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
Old 03-30-2010, 10:03 PM   #9
nplocoman
never finish start another
nplocoman's Avatar
Maybe It,s a 3 on the tree!!!!! The mystery continues! HeHe.
nplocoman is offline   Reply With Quote
Old 03-30-2010, 10:29 PM   #10
67/72junkie
linkage in first pic is not correct for 67/72.pic teeitup has is correct for 67/72 small blockName:  100_1217.jpg
Size:  48.1 KBthese are pics of correct bb linkage,frame pivot pin,linkage rod and linkage arm.shift lever that attaches to the trans is same for small and bb and is in teeitups pic.linkage rod for bb is longer and linkage arm has differant angle .trans sits a little farther back in frame with bb.I do not have linkage for sale only trying to help you get the right part.4x4 frame pivot pin is same as bb I will have to check if 4x4 linkage rod and linkage arm are the same as bb I think so but have to lay them out together to make sure.I can check tomorrow,if so mosesburb might can help you out.
67/72junkie is offline   Reply With Quote
Old 03-30-2010, 10:47 PM   #11
DPowers
One foot in front of the other
DPowers's Avatar
Why don't you check out Kugel or Lokar. Mike's Bump and Grind Shop (mbgmike) is a vendor here and would be able to hook you up.
DPowers is offline   Reply With Quote
Old 03-31-2010, 02:03 AM   #12
c10seconds
c10seconds's Avatar
Soooo.... Teeitup, I think you have what Im looking for... Let me know if I can get it.
Thank you all for the info to help find what I need
Old 03-31-2010, 07:57 AM   #13
teeitup
teeitup's Avatar
Well I sold this setup. I have another setup but am missing the small 'U shaped" piece that bolts to the tranny. $25 plus shipping for the rest. Thanks Randy
1980 chevy swb 4x4
