i am about to start my 6.0 lq9 swap and i have to have air!!!
![]() i have been reading up but i have not found any info on the ac compressor. i plad to do the "fred mod" on the engine stand if needed. so how have you made teh ac work? I really do not want to relocate the compressor if i do not have to.
WTB 73-87 SWB fleetside bed!! 85 C10 6.0 project 69 camaro ls1 / t56 90 mustang lx 75 bronco injected 351w ![]() |
Re: has anyone made the lsx compressor work in a swap?
You can do it but you have to notch and reinforce the frame. If you are a welder/fabricator this is perfect for you, but most people seem to relocate it.
1977 GMC Sierra Grande |
i am a welder / fabricator / penny pincher
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
You do not have to notch or re-inforce anything. The stock compressor fits perfect. You just have to get A/C lines made to clear the frame. I know it's hard to see in this pic but it Works perfect.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. Last edited by STOCKISH; 03-30-2010 at 02:01 PM. |
heres a better pic.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
what manifolds are you running is the manifold close to the rail ???
78 C-10 5.3 LSX -4L60E |
Addicted to Rust
![]() Join Date: Dec 2009
Current trucks: (48 GMC100 320 inliner) Gone (48 Suburban in pieces) Sold 87 GMC CCSB 5.3 4l60E Daily Driver ECTA National record holder XO/PP We never really grow up, we just learn how to act in public. |
yep, i conquer! no notching or reinforcing or fabricating needed
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list ![]() |
Factory truck manifolds. I will need to notch the frame about 1/16 inch to clear the frame on the pass. side.
thanks. i got the dockblock part numbers!!!
Next project: 1970 K10
Check my build thread after this weekend. I will be finishing mine up starting Saturday. Using the Docs Blocks in the above link, the 5.3's original compressor, and everything else will be the original 85's parts (although they will be replaced with new stuff). As stated, no notching or anything like that will be needed with the Docs Blocks extensions.
68shortstep uses these in all of the 67-72 LS swaps he has done. For the most part, that swap is pretty much the same as a 73-87/91 swap.
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE Last edited by glock35ipsc; 03-31-2010 at 03:52 PM. |
