#26 |
haha, ford guys...
Re: interchangeable doors?
#27 |
I would also like to know where the wires and relay is located as i will be placing power doors on my 86. also will these wires/relay work from any year model square body or is has to be the same year the doors came off
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
#28 |
haha, ford guys...
anyone?
#29 |
any one?
#30 |
Great info guys! I'm wanting pw windows and locks myself. I would ASSume the relays would work with any year modle.
1978 Chevy C10 Bonanza, 405hp/440tq 383, tweeked Th350. http://www.facebook.com/#/profile.ph...&id=1116781152 |
#31 |
Sorry about that, been traveling last few weeks... The harness crosses from door-to-door under the dash. The relay is mounted to the firewall/dash near the transmission hump. I just followed the wire bundles from the door thru the front pillar and started disconnecting and cutting the clamps holding it in. Both ends have plug connectors as well as a plug connector at the relay. There was one additional black wire that went to ground, a yellow(?) switched power wire and an orange constant power wire that went to the main chasis harness that I had to cut. I think the relay is the same for all years. I have '85 Suburban doors on my '76 C-10. BTW, The relay has no connection to window operation - it's just for the locks. I spent half a day troubleshooting why the locks wouldn't pop. I looked at a few older posts on this board and found out that the relay shell has to be grounded. I grounded and they work perfectly. It's pretty much plug-n-play, just a few power connections and a ground.
Someone on Ebay has a harness with relay for $15 BIN. I think that's a steal cause it's kind of a bear to get it out, not to mention that the relay is around $40 by itselfHere's the link: http://cgi.ebay.com/ebaymotors/73-87...item230666073c Last edited by soule64; 04-20-2010 at 02:54 PM. Reason: rrr |
#32 |
COOL deal. This might be my next mod.
#33 | |
#34 |
haha, ford guys...
niicee!!! thanks alot!!!!!
