meowMEOWmeowMEOW
Br3w City's Project omgwtfbbq
If you've linked here from my YouTube Channel or other social media sites, welcome to my build hosted here on 67-72chevytrucks. tweet @wtfrevj or IG @rev_j_hd
IF THE IMAGES APPEAR DEAD LINKED OR BLOCKED DUE TO PHOTOBUCKET, PLEASE USE A BYPASS ADDON FOR YOUR BROWSER TO SEE THE IMAGES!!! FIREFOX AND CHROME EACH HAVE A FEW AVAILABLE, THE ONE LINKED BELOW WORKED FOR ME https://outgoing.prod.mozaws.net/v1/...giikdkpmcpkaon I'm not affiliated with this link and take no responsibility for the use of the addon. Only putting the link because it worked for me, and I want everyone to see my build!! We're over 20 pages into it now, but this is the beginning. Welcome to post #1 for... THE H8RDCPTR. (i put the omgwtfbbq as a placeholder thinking i could change it...oops) I was lucky enough to be given most of the original paperwork tracing the trucks history. Started its life in Oklahoma, and spent some time in Georgia and Florida before coming up to WI. I have the original metal service tag and owners manual somewhere too. Started with a 66 short-step with a small back window. The truck was in pretty decent shape or so it seemed. Had a metallic green re-paint in the 80's, some rust that I could see but nothing horrid. Had a different hood since the original had been destroyed by time/rust. ![]() ![]() ![]() The interior was mostly clean, gas tank removed and seats replaced with a later model bench seat. Newer wheel replaces the original also. ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 10-14-2017 at 01:21 AM. |
meowMEOWmeowMEOW
Re: Br3w City's Project omgwtfbbq
Some more details on the project; It has a newer front suspension (newer style truck suspension i believe) lowered 4" and manual disc brakes and power steering.
The front also sports a 1-1/4" swaybar setup. The rear is approx 5-6" lowered, with a small notch to clear the axle. Nitro drop shocks all the way around. Truck rear end with 3:73 posi, moser axles. Mickey Thompson aluminum wheels. The motor is a small block 355; Scat cast crank 2.02 heads with the bowls polished Comp Cams 4wd extreme cam Weiand Sportsman manifold Holley 670cfm Street avenger carb Aluminum drive pulleys Be-cool radiator / electric fan Hooker Super-Comp headers to 2" true dual stainless exhaust. Fabbed aluminum 13 gal fuel cell. k&n filter setup. ![]() It's backed by a 700r4 trans, Hurst shifter and mild stall (can't remember which one)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 09-03-2017 at 12:39 AM. |
meowMEOWmeowMEOW
First step after the basic maintenance was to start rust control, body repair and trying to uncover WHAT is hidden under all that paint.
Brought home the welder and decided to start by filling some holes in the bed rail (p.o must have had a cover on it at some point). ![]() ![]() ![]() ![]() ![]() ![]() Hidden under the paint were even MORE holes, aside from the 40 small ones, a few of these bigger guys were in there. Looks like they had been filled with some sort of foam and then painted right over. ![]() ![]() A few minutes with the welder, and some quick rattle primer and it looks MUCH better. ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() Last edited by BR3W CITY; 10-14-2017 at 01:12 AM. |
meowMEOWmeowMEOW
Started on my fenders, which actually was a happy surprise. After taking the paint down, I found the the major rust was only about 5", the rest of the surrounding metal was clean and rust free. I trimmed the bad stuff out leaving a nice square hole in the fender.
![]() Got my patch made and started the welding process....yikes I'm rusty. I haven't welded sheetmetal in probably 3 years, wire setting are a *****. ![]() I did manage to get a nice clean patch after all was said and done, time for the filler! ![]()
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
meowMEOWmeowMEOW
While the filler was setting on that patch, I moved on to a "small" ding on my door.
It started no bigger than a quarter, but after some sanding...it kept going. There was nice baseball size dent and some wrinkles surrounding it, almost looked like someone was going to repair it but gave up. ![]() LOOK AT HOW THICK THIS SH!T IS! And thats not even the deepest part. ![]() ![]() Got the inside door panel off and started with the hammer and dolly to straighten it out. ![]() Now that I had it much closer to where it should be, I could start with some filler. ![]() Soo much straighter now ![]() Straight like it should be! ![]()
meowMEOWmeowMEOW
This weekend should yield more pics as the stripping process continues. I have also removed the reverse lenses, and sunk the tail light cups into the fenders for a cleaner look...stay tuned.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
What will he find around the next corner? Stay tuned....
Kinda like a paleontologist on his first dig. Having fun?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
meowMEOWmeowMEOW
Hahah ya. Most of the truck is actually fairly solid, it seems like the p.o. did more damage to it then nature did. Hopefully I should be able to finish stripping the bed this week so I can start to fill those holes in the bed rail, and clean up the tailgate etc.
Most of my previous sheetmetal experience has been with newer S10's, trucks etc..working with this nice thick american metal is a relief
#9 | |
Resistance is Futile
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
One day...
![]() Join Date: Apr 2008
Keep up the good work
meowMEOWmeowMEOW
Another weekend gone by, and some more progress made.
Continued on the stripping, working along the rear fender. ![]() ![]() Welding up some holes in the bedrail and starting the prime on the fender ![]() The "bubbled" finish under the rail is some older paint that chem stripper was soaking on. ![]() ![]()
meowMEOWmeowMEOW
Starting to strip the tailgate
![]() CRAP! Hit myself with the grinder while moving it in a tight space ![]() ![]() Finished the tailgate ![]() Welded the front bed panel, and then got a little rust hole surprise under the finish. ![]() ![]()
Member of the longbed union.
No blood no foul, I guess you can kick it back. I cant tell you how many times I've done that or on the bench grinder with small stuff.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
60-66 Nut
Good thing you had gloves on....could have been worse.
Your truck's coming along nicely.....keep at it.
#15 |
Nice work Im gonna start on mine after the summer. Are those the stock tail lights fabbed into the rear quaterpanels?
#16 |
meowMEOWmeowMEOW
thanks for the comments guys. I ALWAYS wear glove when grinding now; about a 3-4 years ago I had a grinding wheel on it and it slipped when I stepped on the cord. I've got a 1/4" gap in my fingerprints from that one.
62 bowtie - They are LED lens/bulbs. Its the stock size lens, with integrated led's and the stock style plug. I took the reverse lights out, and welded the stock light buckets where the reverse lenses use to mount. I sealed it from the back, and then can screw in the lenses as normal from the front.
#17 |
One foot in front of the other
![]() Join Date: Aug 2008
Great progress
#18 |
meowMEOWmeowMEOW
Started taking the paint off of the drivers door. Very solid but i did get a few surprises.
![]() Another dent in the same place as the big dent on the passenger door. Its tough to tell what happened, but weird its on the same spot. This side is nearly as bad. ![]() What the heck is this? Looks like a couple of phillips screws that they filled right over. Is this a stock mirror mount or something? ![]() A little bit of crust on the bottom of the door, shouldn't be a tough patch though. ![]()
#19 |
meowMEOWmeowMEOW
Sanded down the paint and bodywork on the front fender and got a nice size rust hole. A little bit worse than the other side, but handle-able. There were a couple pinholes a bit higher up too.
![]() Cutting out the rot ![]() The gnarled steel. ![]() And the hole ![]() Cut a patch panel to fit. Luckily the edges were still good on the original steel, so the patch was easy to cut in. ![]() ![]() ![]() Out with the old and in with the new. ![]()
#20 |
meowMEOWmeowMEOW
its been a while since I posted an update. Alot of progress has been made, and the rest of the photos will come later this weekend.
A couple of changes so far ![]() ![]() Fenders are off and all of the stripping has been mostly done. The besides have been stripped now, nice and rust free! ![]() Later this weekend I will have some shots of the finished front filler work, and some progress on patching the lower doors.
#21 |
Redneck Hillbilly
Nice work. Subscribed.
#22 |
digging on those shark shoes Cool
#23 |
meowMEOWmeowMEOW
haha, thanks man. The shoes are actually painted P52 style, with the mouth on the nosecone, there are kill marks on the sides, and a few various insignias. I think they are from Circa but I can't remember exactly.
#24 |
Lookin good...
RED NOSE '65 LOS HITTERS C.C DALLAS, TEXAS The making of a Red Nose... http://www.67-72chevytrucks.com/vboa...d.php?t=396518 |
#25 |
Sunburst C10!!!
looks great
Gage 1967 C10 Shortbed Stepside |
